Flamenco Guitar—Gypsy Style
in FAQ Posts: 27
Anybody played a flamenco guitar for ‘Le Pompe’ style? The reason I ask is a flamenco guitar is a percussive instrument—able to cut through on chords. Your thoughts on this subject?
    I like it, at least for leads, for that reason.
    Not necessarily what you consider a flamenco guitar, but Raphael Fays plays this style of music on a nylon string guitar. He's unlocked some incredible flamenco technique using a plectrum, and his Django-style stuff is second to none.
    https://www.youtube.com/watch?v=la4ujB2JkIs
    There's Lulo Reinhardt with his signature Kremona guitar. Although I don't know how much flamenco design is in there, I can't but think that it's a punchy, percussive guitar.
    Kremona flamenco guitars are good and tend toward percussive, but 12-fret and no cutaway.
    Lulo's model is 14 fret to the body (but maybe that's not what you meant).
    No. They have a regular flamenco guitar model.
    Many thanks for all the above info.Much appreciated.
    Lulo has actually two siganture models. One is a 12 fret with a classical neck and the other is the 14 fret with a thinner neck. The 14 fret looks very interesting to me and I'd like to try it out if I could. I'm aware of one local singer-songwriter type who uses the 14 fret as his main instrument and that seems like a brilliant use for this guitar. To use this instead of a traditional folk style guitar. The nylon strings are softer for a casual player and that guitar still retains a thinner neck and a built-in microphone.
    For gypsy jazz though, the nylon strings are an acquired taste. Some use them and sound good but with steel strings they'd sound better. So there's that.
    I'd go with a regular classical over a flamenco, flamencos have low action and less strong tension related to the flamenco technique and ultimately will probably be less loud for a given amount of input.
    No practical experience here tbh but they are designed a little differently to be percussion instruments and unless you're beating the top, you're probably not taking advantage of that.
    I tried to make one and failed pretty miserably for not understanding the differences. Oh well.
    BucoJoonas
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.004891 / 1.052658]
