Tuning the B string
kungfumonk007kungfumonk007 ✭✭✭✭
in Welcome Posts: 428
I got sick of it. Luckily AI made me a programmer... so I built an app for our guitars that allows you to callibrate your guitar automatically or manually then tune to a region or to a chord. Enjoy
I also made this very very cool app that drills different time/feel/microtiming excercises. It is killer. No adverts, no pay, I made these with ai so obviously I am not asking for anything, they are just really cool 😎 My favorite excercise is: eighth-note-orientation, two-anchor switchboard. But it also has micro-timing feel excercises based on peer reviewed research for both swing and brazillian feels. It has dramatically improved my interior 8th note feel, and as far as I know it is the only metronome that works this way.
https://play.google.com/store/apps/details?id=com.aaronwalkermusic.timemonster
BucoBillDaCostaWilliamsScoredog
    Just fyi I haven't looked at your app yet but I'm working on one that does some similar stuff at the moment (as well as a lot of other things).
    Just wanted to say I didn't copy your ideas.
    It is weird with this vibe coding stuff, I think whatever I'm working on that I think is cool, 26 people are probably doing exactly the same thing.
    Anyway, sounds cool! Great minds....
    BillDaCostaWilliams
    Just going to say...I'm suspicious of sweetened tunings. For a guitar with a zero fret, if your bridge compensation is good (admittedly, most gypsy guitars don't have accurate bridge compensation) you should be aiming towards equal tempered open strings and then equal tempered fretted notes. While it's unlikely you'll really get there, in my experience trying to fudge one way or another can really cause a cascade of stacking intonation problems.
    My personal tuning strategy is using an equal tempered tuner to tune the open strings, have a compensated bridge in the exact right spot and then hope for the best.
    Is there a demo about how you're supposed to use the tuner, calibration and what is it effectively doing?
    Whatever you do is a compromise. It's all about what can you tolerate. I couldn't drink coffee with the creamer, someone else wouldn't touch black coffee.
    Tony Rice, famous bluegrass guitarist, used to tune correctly but then very slightly lower the pitch of the B string. Earl Scruggs, famous banjo player, had the third fret cut for the unwound 3rd (G) string and moved, as a little piece, slightly toward the 4th fret.
    notably, these are instruments with a nut, not a zero fret. Not saying it's totally unnecessary with a zero fret instrument but a lot of intonation errors in guitars come from the stretch in the string between the nut and the first fret. But that's if your bridge is in the right place, which, it very well might not be.
  • edited November 15 Posts: 6,163
    Lowering B is almost a must. On my, Jeremy made, bridge it's compensated so usually it's fine.
    Who will be the first in our world to build one?
    Maybe European GJ guitarists in the 1940's - 70's on used string "bending" to compensate for non temperate bridge/guitar capability. Does this "embellishment" genre style continues now even if a guitar has a quality bridge? Most experienced guitarists have a personal tuning sequence they use and a quality tuner that shows open string "temperance" and possible subtle tweaking via a soft thumb strum from low E to high E. I've used for 5 years now a top level poly tune by TC Electronics. Very satisfied with it's capability on my guitars!
    maybe I'm missing what you're saying but the TC tuner tunes in equal temperment.
    There are very few really compensated gypsy bridges that I've seen. Most of them have a straight saddle that goes diagonally but doesn't change between the wound and unwound strings. Obviously that was what Django played but it is limited intonation wise.
    edited November 15 Posts: 428
    It doesn't "solve" bad intonation it creates an easier go to setting to compensate - that is why there are 3 regions - I usually tune it to the middle unless I know I am going to be playing a piece that lives in another region - it is still out of tune, just a better compromise. I also use bends to compensate for intonation but that isn't always possible.
    Tune it normally. Then hit the callibrate function. You play the open string, then it asks for you to play the 12th fret. That gives it a decent estimate of your guitars intonation - not perfect but way better. I was doing this already by tuning different strings at different places on the neck - this is just faster and easier.
    And yes - I know Tony - he was talking about it and it was what gave me the idea to make this finally. It also has a natural 3rd function which I don't particularly like, but might be good for some Bach pieces.
    Paul - I respect your luthier creative guitar build ideas and knowledge but would you please respond and comment to my initial question of "String bending" compensation of bridge intonation and not your diversion to tuner temperance!
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.005007 / 1.060234]
