Thanks Romain, I love this tune. Just confirming, you play the riff, the last note is beat 1 of a 4/4 bar and then you start counting the blues form, correct? So much fun.
yes ! well there s a tiny V degree after the last note, so i think if you count there in 5 empty bars bw the last notev of the intro and the first note of the solo
That's right, they (Romain's band) are not putting the weird long bar before going into the blues form. It's directly into 4/4. First bar sounds like two beats of the I and then two beats of V. Then the band sits out for 3 the first 4 bars before coming back in on the IV chord (i.e. the fifth measure of the blues form). In contrast, Django's recordings do have also a 5/4 bar before the blues form, as shown in the sheet posted above.
Interestingly, the first version of this tune has a bar of 7 beats between the riff, not a bar of 5! Most people these days use the bar of 5, and are probably more familiar with one of the later recordings.
Pretty sure it's 1 measure of 4/4 that starts with the last note of the riff as the downbeat. (I'm calling it the wasted measure with the V I)) and then the first four measures of the blues, band coming in on measure 5 (Eb).
Yeah, you're right Paul. The spot where Romain quotes La Marseillaise is the first measure of the blues form, and there's also an extra bar before that.
The first 3 bars of the riff are in 3/4 but the last bar is in 5/4 then the Bb blues begins normally in 4/4
Count it out to the recording above, I'm 99% sure that last measure is a bar of 4/4.
The best way is to write it down to be certain it works...
Here's the official version:
On some occasions Django plays even a 7/4 bar break instead of a 5/4 bar break
I have that but if you count it out in the performance above, I believe the measure before the blues form starts is 4/4.
for 3the first 4 bars before coming back in on the IV chord (i.e. the fifth measure of the blues form). In contrast, Django's recordings do have also a 5/4 bar before the blues form, as shown in the sheet posted above.Interestingly, the first version of this tune has a bar of 7 beats between the riff, not a bar of 5! Most people these days use the bar of 5, and are probably more familiar with one of the later recordings.
Check it for me.
Same thing happens @2:00 after the bridge.
first time I've been right about anything musical. Big day for me!
