Home / Amplification / Pickups / Schertler Pickups and Preamps / Stat Pickups / Schertler STAT-C-Set Electrostatic Transducer for Cello (with Stat-Pre)
Application
  • Ideal for rock, fusion and jazz players where high amplifier levels must not present a handicap
Features
  • High feedback resistance
  • Impressive “bridge sound”
  • NO piezo harshness or distortion
The patented Schertler STAT-C electrostatic bridge pickup stands out for its high feedback resistance and for delivering an impressive bridge tone without the harshness or distortion of piezo pickups. STAT-C delivers wonderful, rich lows and smooth, clear trebles, and works perfectly with signal processors and effects thanks to its strong, solid signal.
The STAT-C is the choice for the cellist in a modern and loud musical environment. The standard STAT-C Set includes pickup, cable and the battery-powered STAT-PRE preamplifier with volume control.
Amplification may be managed by any amp or with a full-range amplifier system such as for example the Schertler PUB 280 and 380 active loudspeakers with bass extension.
Item: 6561
$872.00 $685.00 | Out of Stock | Stock Notification
Amp Specs
Schertler STAT-PRE Electrostatic Preamp
The Schertler STAT-PRE preamplifier is the perfect choice for use with the Schertler series of electrostatic transducers for classic string instruments. Versatile and easy to use, STAT-PRE provides volume control in a compact package. An innovative sub-bass filter protects the house system, or your on-stage amplifier, from distortion or potentially harmful signals caused by low-frequency spikes. Class-A constant-current design ensures faithful sound reproduction while providing up to 500 hours of playing time from a single 9-volt battery. Manufactured with a cast aluminum housing, the STAT-PRE can be floor-mounted or worn by the player with the optional belt clip. Stat-Pre Specs Stat-Pre Manual
$238.00
Schertler Yellow Single
$705.00
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.025811 / 2.827728]
