Home / Amplification / Pickups / Schertler Pickups and Preamps / Stat Pickups / Schertler STAT-V Electrostatic Transducer for Violin/Viola (Pickup Only)
WARNING: THIS PICKUP REQUIRES EITHER A SCHERTLER PREAMP (STAT PRE OR PRE AIII) OR A SCHERTLER AMPLIFIER TO OPERATE (UNICO OR DAVID). CONVENTIONAL THIRD PARTY PREAMPS WILL NOT FUNCTION WITH THIS PICKUP.
Application
  • Ideal for rock, fusion and jazz players where high amplifier levels must not present a handicap
Features
  • High feedback resistance
  • Impressive “bridge sound”
  • NO piezo harshness or distortion
The patented Schertler STAT-V electrostatic bridge pickup for violin and viola stands out for its high feedback resistance and for delivering an impressive bridge tone without the harshness or distortion of piezo pickups. Located under the high string in the bridge wing cutout, STAT-V delivers a direct and punchy sound. Unlike shrill or metallic piezo pickups, STAT-V accurately reproduces the warm sound of your strings. The bottom of the violin/viola sound is impressively reproduced with all its depth and body, while the highs are clear and bright.
Amplification may be managed by the house PA or with a full-range amplifier system such as for example the Schertler PUB 280 active loudspeaker.
$452.00 $370.00 (Save 18%)
Amp Specs
Schertler STAT-PRE Electrostatic Preamp
The Schertler STAT-PRE preamplifier is the perfect choice for use with the Schertler series of electrostatic transducers for classic string instruments. Versatile and easy to use, STAT-PRE provides volume control in a compact package. An innovative sub-bass filter protects the house system, or your on-stage amplifier, from distortion or potentially harmful signals caused by low-frequency spikes. Class-A constant-current design ensures faithful sound reproduction while providing up to 500 hours of playing time from a single 9-volt battery. Manufactured with a cast aluminum housing, the STAT-PRE can be floor-mounted or worn by the player with the optional belt clip. Stat-Pre Specs Stat-Pre Manual
$238.00
Schertler Yellow Single
$705.00
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.023343 / 2.637627]
