Home / Schertler DYN-E Ethnic Instrument Transducer
World Music. A broad term indicating music, musicians and instruments from around the world: from China the Chinese Harp, from Africa the Kalimba, from Switzerland the Alpenhorn, and so on.
The DYN Series of electro-dynamic transducers from Schertler allows total freedom of movement to performing musicians while easing the problems of isolation, bleed and feedback facing the sound engineer.
Installation is easy - special inert adhesive putty is provided to mount the pick-up to the instrument body. The best location for each instrument’s sound is quickly found through our indications or through experimentation with placement.
Balanced, low impedance output through an XLR connector means DYN-E connects directly into an amp or a microphone input of the studio or stage mixer.
As with other Schertler electrostatic and electro-dynamic transducers, DYN-E works best through a full-range amplification system, such as our UNICO/DAVID amplifiers or Schertler’s PRE-A III preamplifier connected with our active loudspeakers.
Item: 6531
$675.00 $499.00 | Out of Stock | Stock Notification
Adhesive Putty - Single Pack
$24.00 $20.00 (Save 17%)
Schertler Yellow Single
$705.00
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.014418 / 1.349648]
