Home / Amplification / Pickups / Schertler Pickups and Preamps / Schertler DYN-G P48 Guitar Pickup
The Schertler DYN-G P48 is Unlike Any Other Pickup on the Market
Nearly all guitar pickups use one of two technologies: magnetic or piezo, both of which color the sound in ways that produce a sound that is unnatural, and often harsh and irritating. The Schertler DYN-G P48 is unique in that it uses electrodynamic technology that yields the most natural possible sound, producing a transparent, accurate reproduction of your instrument.
The Schertler DYN-G P48 is Easy to Use and Requires No Permanent Installation
The Schertler DYN-G P48 easily mounts to any guitar using the supplied, reusable finish friendly putty. It takes just seconds to mount and can be easily removed and stored in your instrument case when not in use. Since no permanent installation is required, the Schertler DYN-G P48 can be used on any instrument you own, removing the need to outfit each instrument with its own pickup. Also, the movable nature of this pickup allows you to achieve an endless variety of tonal characteristics by placing the pickup in different locations on the top back, or even inside your instrument.
The Schertler DYN-G P48 is Designed to Produce the Warmest, Clearest Tone.
The Schertler DYN-G P48 is equipped with a balanced, XLR cable that minimizes noise and RF interference. The pickup is constructed using Class A electronics which result in the most detailed and satisfying tone possible. This pickup requires 48V phantom power. When used in conjunction with a Schertler amplifier or preamp such as the Schertler Yellow Single, Schertler's proprietary RESON control will reduce feedback and improve the tone, allowing for as much as 25% more volume before feedback.
$689.00 $645.00 (Save 6%)
Specs
Output impedance 4.7 Kohm @ 1 KHz
Frequency Response 20 Hz to 20 kHz
Dynamic range 139 dB, 145 dB typical
Sensitivity (on instrument) ca. -30 dB
Sensitivity (theoretical) -62 dB/@ 1um ampl.
Mechanical decoupling Butterworth 2nd order, Q=6
Temperature range -20° C to +70° C
Minimum operating voltage 22 VDC
Active EQ Customized for each instrument
Electronics all Class-A
Contacts All hard gold plated 0.5 mm
Connection XLR balanced
Cable length 2.2m
Adhesive Putty - Single Pack
$24.00 $20.00 (Save 17%)
$705.00
Love it!
I play in a flamenco duo and this pickup is perfect!
Submitted by Jane on 08/02/2018 10:03:51 AM.
Great Sound - Feedback Problems
Pros: Great Sound
Cons: Feedback
This is a great sounding pickup but I had feedback problems with it. I play mostly acoustic rock in pretty big performance spaces and I couldn't get this pickup loud enough. It does sound great though, and if you're playing strictly acoustic music like bluegrass or classical, it would be a really good choice. Michael suggested I try the Schertler AG6 instead and that is so much better for what I do as it can get way louder.
Submitted by stringslinger on 12/13/2017 09:29:48 PM.
DYN-G P48
Pros: Great sound
Cons: External wires
So glad Michael recommended this to me! It sounds fantastic....
Submitted by Marc D. on 08/20/2017 04:38:43 AM.
Very Natural
Pros: No drill install, non permamnet
Cons: None
I use the DYN-G on my vintage Epiphone archtops and it's just perfect. It captures the natural sound of the instrument without having to modify the guitar in any way. I loved this unit so much much, I bought the DYN-B and DYN-V for the other members of my band. Our live sound problems are solved!
Submitted by swingjazz on 12/31/2016 04:04:16 PM.
Best Acoustic Pickup!
Pros: Easy to Install, Great Sound
Cons: Requires Phantom Power
I've tried them all, piezos, mics, magnetic pickups, etc. The DYN-G P48 beats them all by a mile. It's so natural, easy to install, and very feedback resistant. Love it!!!
Submitted by Jack on 06/02/2015 12:07:30 AM.
Great Sounding!
Pros: Great Natural Sound
The Dyn-G guitar pickup is easy to use and produces a great natural sound. I searched on the internet for the best price on this pickup and found Django Books to have the best price. I recommend this product to anyone who wants a natural sound for recording or performance. I also recommend this product for anyone who wants to use a pickup on multiple guitars and does not want to permanently mount a pickup in their guitar.
Submitted by GTRZZZ on 11/12/2012 08:12:25 AM.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.025296 / 2.559746]
