Schertler DYN-C P48 Cello Transducer Schertler DYN-C P48 Cello Transducer Schertler The Schertler DYN-C P48 is unique in that it uses electrodynamic technology that yields the most natural possible sound, producing a transparent, accurate reproduction of your instrument. Arts & Entertainment > Musical Instrument Accessories > String Instrument Accessories > Cello Accessories schertler-dyn-c-p48 DYN-C P48 543.00 DjangoBooks.com
Home / Amplification / Pickups / Schertler Pickups and Preamps / Schertler DYN-C P48 Cello Transducer
The Schertler DYN-C P48 is Unlike Any Other Pickup on the Market
Nearly all cello pickups use one of two technologies: magnetic or piezo, both of which color the sound in ways that produce a sound that is unnatural, and often harsh and irritating. The Schertler DYN-C P48 is unique in that it uses electrodynamic technology that yields the most natural possible sound, producing a transparent, accurate reproduction of your instrument.
The Schertler DYN-C P48 is Easy to Use and Requires No Permanent Installation
The Schertler DYN-C P48 easily mounts to any cello using the supplied, reusable finish friendly putty. It takes just seconds to mount and can be easily removed and stored in your instrument case when not in use. Since no permanent installation is required, the Schertler DYN-C P48 can be used on any instrument you own, removing the need to outfit each instrument with its own pickup. Also, the movable nature of this pickup allows you to achieve an endless variety of tonal characteristics by placing the pickup in different locations on the top back, or even inside your instrument.
The Schertler DYN-C P48 is Designed to Produce the Warmest, Clearest Tone.
The Schertler DYN-C P48 is equipped with a balanced, XLR cable that minimizes noise and RF interference. The pickup is constructed using Class A electronics which result in the most detailed and satisfying tone possible. This pickup requires 48V phantom power. When used in conjunction with a Schertler amplifier or preamp such as the Schertler Yellow Single, Schertler's proprietary RESON control will reduce feedback and improve the tone, allowing for as much as 25% more volume before feedback.
$689.00 $543.00 (Save 21%)
Specs
Output impedance 4.7 Kohm @ 1 KHz
Frequency Response 20 Hz to 20 kHz
Dynamic range 139 dB, 145 dB typical
Sensitivity (on instrument) ca. -30 dB
Sensitivity (theoretical) -62 dB/@ 1um ampl.
Mechanical decoupling Butterworth 2nd order, Q=6
Temperature range -20° C to +70° C
Minimum operating voltage 22 VDC
Active EQ Customized for each instrument
Electronics all Class-A
Contacts All hard gold plated 0.5 mm
Connection XLR balanced + Binder
Cable Length 1.3m
Adhesive Putty - Single Pack
$24.00 $18.00 (Save 25%)
$592.00
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013372 Seconds Memory Usage: 1.412979 Megabytes
