Home / Manouche / Manouche Modele Concert 12 Fret Nylon String D-Hole Guitar with Hiscox Hard Shell Case
The Manouche Concert. A faithful reproduction of the nylon string Maccaferri Concert model. Similar to the Orchestre but with fan bracing, flat top, two part saddle to improve intonation, glued down bridge.
  • European solid spruce top book-matched with laminated rosewood back and sides
  • 12 frets to the body
  • Body bindings in ebony with white-black-white purfling
  • Mahogany neck with ebony fingerboard, slotted head stock and pearl dots
  • Bone nut with traditional “zero” fret
  • Dovetail neck-to-body joint
  • Scale length = 640.00mm
  • Nut width: 48.00mm
  • Body Length: 470.00mm
  • Lower bout 406.40mm
  • Upper bout 285.75mm
  • Traditional Selmer horizontal cutaway
  • Characteristic 'D' sound hole with multiple traditional rosette surround
  • Ebony bridge with moustache
  • Tuning gear as original selmer
  • Adjustable truss rod and traditional Selmer trapeze tailpiece with felt protector
  • Comes fully shop adjusted
Item: 9918
$1,620.00 | Out of Stock | Stock Notification
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.014361 / 1.460312]
