Barault is one of the very few luthiers today actually making Selmer copies with a real pliage. He uses the method that Selmer did...the top is bent with a hot iron which creates a fold, or "pliage," in the top just under the bridge. 99% of Selmer copies being made today have forced tops which generally don't have the punch, volume, and quick attack that the pliage tops have.
Barault certainly wins the award for weight...this guitar is feather weight at only 3.8 pounds! Hard to find anyone making guitars that lightweight today. The lower weight allows the guitar to resonate freely....no wonder it sounds so good!
| Brand | Barault |
| Year | 2019 |
| Model Number | D Hole |
| Condition | Excellent |
| Nut Width | 1 3/4" |
| Body Depth | 4" |
| Top | European Spruce |
| Neck | Walnut |
| Fingerboard | Ebony |
| Binding | Ebony |
| Finish | Nitrocellulose |
| Tailpiece | Barault Gold |
| Tuners | Barault Brass Closed Tuners |
| Action | 2.8mm |
| Strings | Argentine 1610MF |
| Case | Molded Foam |
| Truss Rod | Yes |
| Weight | 3.9 lbs |
| Soundhole | D Hole |
| Scale Length | 670mm |
| Size | 15 13/16" |
| Back and Sides | Indian Rosewood |
| Fret Neck | 14 Fret |
| Pickup | None |
