Tornavoz
MichaelHorowitzMichaelHorowitz SeattleAdministrator
i just became aware of the tornavoz, a resonator like cone added to the soundhole of a classical guitar, which was pioneered by the legendary Antonio Torres (father of the classical guitar). See photo below.
It's interesting how so many of the ground breaking luthiers of the last 2 centuries tried to implement some sort of resonator which ultimately was rejected by the public (Macafferi's resonator and Loyd Loar's Virzi tone producer come to mind).
The tornavoz fell out of favor among classical builders by the 20s, but there seems to be a resurgence of interest in it. Francisco Tárrega, the legendary pioneer of classical guitar, had a maple Torres guitar with a tornavoz. He considered it one of best instruments he ever owned noting that:
“In addition to the spontaneity of sound, perhaps due to its tornavoz, there was a clear, warm timbre as if it were of gold. The balance between bass and treble was proportionally exact in volume and the duration of its vibrations equally generous throughout the fingerboard. It sufficed to finger a perfect chord in order that, by plucking only the three bass notes one could clearly perceive the harmonics of the other strings.”
This guitar had a soundboard that was less then 1mm thick, wow! But the top did eventually cave in...but I bet it was fun while it lasted...he eventually got a rosewood guitar sans tornavoz that he liked even better.
Anyway, it's an interesting anecdote in the development of the guitar. More here: http://www.guitarsalon.com/articles.php?articleid=38
Who wants to be the first to have a Selmer style guitar with a tornavoz? :D:D:D
  • fraterfrater Prodigy
    My luthier and friend Lucio Carbone makes some breath-taking Torres copies here in Milan:
    http://www.luciocarbone.it/liuteria_bs.htm#copieTorres
    I'll ask him what he thinks about the tornavoz, I had never heard about it!
    This luthier seems to be really gung-ho about the tornavoz:
    http://www.frenchguitars.com/tornavoz.html
  • DuozonaDuozona Phoenix, AZNew
    Here is an interesting link to a home job version:
    http://www.hago.org.uk/faqs/contrabass/construction.php
    They really do effect these particular contrabass guitars. Listen here:
    http://www.hago.org.uk/faqs/contrabass/ ... -after.php
    -Chuck
    Most of these 'resonators' are actually tuned ports - the Mac one was - or at least it functioned like one. The Tornavoz definitely is - it even looks like one. Essentially - for a chamber of given size and acoustic compliance, if you make the port longer, you lower the frequency of the chamber... think of blowing across a beer bottle... then take a sip & blow again... lower frequency, right? Same principle. It was described by a guy named "Helmholz" back before there was hair... and he (humbly) called it the Helmholz Resonator. ;-)
    Most guitar bodies are tuned somewhere around G or A. The thing about it is, that if you want to do a lot of first position playing or open chord playing or drop-tunings or whatever, you might want a guitar whose bass is accentuated nearer those frequencies. Not coincidentally - if you take a ~0.6 square foot chamber (assume 3.75" x 18.5" x ~14" being an average guitar) and give it a 3" port that is about 2.75" deep.... you tune it to ... you guessed it... about 80hz which is approximately a low E.
    It is, in a fashion, a resonator. Likely the thing that is resonating is not what you'd guess though... the plug of air in the vent is resonating - or rather it's moving in and out fast - I guess you could call that resonating; Helmholz did - and its mass is increased when you lengthen the port... higher mass = more momentum = slower to change directions = lower frequency... roughly... there's more to it than that, especially in a guitar where at least one of the surfaces of the chamber is a passive radiator (resonator) with its own moving mass / resonance etc. But that's basically the concept.
  • spinalityspinality Gardiner, WA, USANew
    I am thinking hard about experimenting with these gizmos for 7-string, 8-string, and baritone instruments. For the same reason the tornavoz has dramatic effects on a contrabass classical guitar (http://www.hago.org.uk/faqs/contrabass/construction.php), it should provide more options for balancing tonal color on guitars with lower-pitched strings. It remains to be seen, of course, what the ramifications will be on a Selmer-style instrument. (Sorry if bringing this old thread back to life is poor etiquette. But I thought it would be helpful to mention the 7-string issue here.)
    -- Trevor Hanson, Gardiner WA
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.004859 / 1.052658]
