I'm wondering exactly how a magnetic pickup like the Stimer works, since I was under the impression that silver wound copper strings are non-magnetic, am I simply mistaken? or perhaps the Argentines are simply a bit less effcient than a nickel steel string or something of the sort... they still have a steel core right?
so if the reissue Stimer is designed to compensate for the string imbalance, how do vintage pickups fare in general? i've got an old Regal archtop, I use Argies on her and she sounds great, i think closer to the gypsy sound i hear on records than the couple of Gitanes I've played in person, which sounded too... flat. i guess. But yeah i was planning on putting like a vintage DeArmond on just to check it out and was hoping that it wouldn't be in vain, since I do love the Silver Strings so.
just wanted to show off.
Even the Dearmond Guitar Mikes and Rythym Chiefs are better balanced than a Stimer (Reissue or original).
Argies or Bronze will not work as well as nickel, but will work.
Marc
www.hotclubpacific.com
And these new benedetto pickups? Are they good for gypsy guitars?
I'd recommend the deluxe...it's by far the best sounding of the lot. Not so brittle, nasal, and quacky like the regular bigtones. The only issue is that it's output gain is lower. It's not a problem as long as you have a powerful amp like an AER of Schertler. But if you're using a weaker amp you may need a preamp to boost the gain a bit.
The Super Bigtone also sounds good, but not as good as the Deluxe. But it has a really hot signal so it's loud!
[quote]And these new benedetto pickups? Are they good for gypsy guitars?[/quote]
The benedetto PUs are humbuckers, so you'd have to drill some holes in your guitar which will kill the acoustic sound. These are more for archtops are for people who want to turn their Selmer into an elctro/Selmer hybrid. Like this:
How are the Bigtones configured for external mounting? I have heard that these are'nt any good..
Josh will build an external mount if you choose that option. I've never heard of any problems with them....the pickup and sound are the same. the only difference is you don't drill holes in the guitar so the pickup can be removed easily. People who don't want to drill holes in their guitar (especially if it's a vintage guitar) or like the flexibility of being able to take pickup off choose this option. I've never heard any complaints...
