Home / ZT Amplifiers / ZT LUNCHBOX
ZT LUNCHBOX
The ZT Lunchbox, the new Miracle Amp!
The ZT Lunchbox has set a new benchmark for small micro-amplifier performance. This tiny 9lb amp packs a whopping 200 watts of power and is literally the size of child's lunchbox. The Lunchbox amp is ideal for those who play small venues, but can also perform well in large halls if combined with the Lunchbox CAB extension speaker.
A small amp with a big sound!
The tonal characteristics of the ZT Lunchbox are quite surprising for such a small amp. It produces thick, warm leads when used with either single-coil or humbucking pickups. Chords are complex with many of the sweet overtones you'd expect of tube amps.
The Lunchbox is loaded with useful features
The Lunchbox amp is well designed with a host of useful features. It includes a 6.5" speaker, variable di/headphone out, and external speaker out. an aux input for CD or MP3 players, and 115V/230V voltage switch.
ZT LUNCHBOX
ZT LUNCHBOX
Item: 6900
$599.00 $449.00 | Out of Stock | Stock Notification
Amp Specs
Features:
  • Ambiance simulator (open-back cabinet effect)
  • Variable Headphone or DI Output
  • Custom High Performance 6.5" Speaker
  • Ext. Speaker Output (8 ohms min.)
  • Auxiliary Input on 1/8" Stereo Jack
  • 115V/230 Voltage switch
System Design:
  • 200W Class A/B Power Amp
  • Ultra-low latency circuit
  • Pure analog front-end, with diode overdrive capability
  • Proprietary dynamic tone shaping
  • Vintage modeled tone stack
  • Class A/B output stage with unregulated linear supply
  • Sealed-box speaker tuning
Specifications:
Dimensions:  7.5" x 9.8" x 4.4"/192mm x 250mm x 112mm
Weight: 9.5 lbs./4.3kg
Peak Output: 120 dB at 1 meter
Controls: Volume, Gain, Tone, Ambiance, Line Out/Headphone Level
ZT Lunchbox Manual
Advanced Users Guide
Lunchbox White Paper
ZT LUNCHBOX CARRY BAG
ZT Amplifiers LUNCHBOX CARRY BAG
$39.99
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.036861 / 5.252914]
