ZT LUNCHBOX ACOUSTIC ZT LUNCHBOX ACOUSTIC ZT Amplifiers The ZT Lunchbox Acoustic amplifier packs 200W of power into an ultra lightweight 2 channel combo! Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers zt-amplifiers-lunchbox-acoustic LBA1 4.3 3
3 5
I really wanted to love this amp. It really light and small. I live and work in NYC and this amp would make my life so much easier. It sounds best with steel string acoustics. I felt that every other acoustic instrument that I used did not get the sound I was looking for. I tried it on my Johnny Smith,Gibson F and A style mandolins, acoustic steel strings, nylon classical and ES 175. It works pretty well with the 175. Wierdly it has too much mid range and the. EQ will not allow you to thin it o...
5 5
I ordered the ZT Lunchbox Acoustic not fully certain of what I'd receive. My practice amp was not sounding the way I wanted and I was tired of fiddling with my power mixer. I needed something that would allow me to practice with a clean sound, give me a microphone channel and some power. On paper, this looked to fit the bill. I have to say I was more than happily surprised. The sound from the 6.5" speaker was better than I imagined (especially on the low end) and when running the signal out...
5 5
I'd like to share a few of my first impressions with Lunchbox Acoustic. While I'm giving it a full 5 star rating it should be seen in context. Meaning it's great for what it is! I could've compared it to some higher end $700 and up amps and in that world it certainly wouldn't rate 5 stars. While I read and saw many glowing reviews amateur and pro alike I can't say this is a killer amp in all respects. For one I'm still to be convinced of it's power rating and high, clean headroom. It is cl...
499.00 DjangoBooks.com
Home / ZT Amplifiers / ZT LUNCHBOX ACOUSTIC
The Lunchbox Acoustic is ZT’s first two-channel amp, a compact masterpiece with perfect features, flexibility and tone for the performing acoustic musician. The ZT Lunchbox Acoustic is a top quality, dedicated microphone channel and separate instrument channel each sport the individual controls you need and the rich tonal palette you want. Complemented by 200W of clean amplifier power, anti-feedback circuitry, a pro-grade reverb and highly flexible signal I/O, the Lunchbox Acoustic is your affordable, one-box performance solution for the home, the club, the café or the recording studio.
The original ZT Lunchbox took the music world by storm, and proved that our unique amp technology can pack an amazing amount of sound into a tiny, reliable, and attractive package. Now, with the Lunchbox Acoustic, this level of performance is available for working singer-songwriters, vocalists and demanding acoustic players of all styles. The Lunchbox Acoustic is easy to carry and easy to use, but provides plenty of clear, natural, room-filling sound when you need it. Designed with logical simplicity but able to adapt to each unique environment, instrument and individual voice, the Lunchbox Acoustic offers the features you need to get the very best out of real world performing situations.
The Lunchbox Acoustic holds a down-to-earth visual appeal, yet remains unmistakably ZT. That little red circle on the front lets you know you’re looking at a uniquely powerful compact amp. Like the original Lunchbox, unmatched in its combination of performance, portability, it is sure to become the best friend of working musicians everywhere.
6900 - ZT LUNCHBOX ACOUSTIC
$799.00 $499.00 | Out Of Stock | Stock Notification
Amp Specs
Features:
  • Mic channel strip with 1/4” and XLR inputs
  • Instrument channel strip with 1/4” input
  • Dedicated Mic Gain control
  • Dedicated Instrument Gain control
  • Plate Style Reverb with independent channel controls
  • EFX Loop
  • 3-position Anti-Feedback Control with bypass
  • Anti-Clip limiting circuit
  • Phantom Power
  • Variable Headphone/DI Output
  • Custom Ultra-High Performance 6.5” Speaker, Switchable
  • External Speaker Output
  • Aux Input on 1/8” Stereo Jack
  • Voltage switch 115V/230V
System Design:
  • 200W Class A/B Power Amplifier
  • Ultra-low latency circuit for player responsiveness
  • Pure, Hi-Z analog instrument front-end
  • Low Noise Balanced Mic Preamp, with interference rejection
  • Proprietary dynamic tone shaping
  • Vintage modeled instrument tone stack
  • Class A/B output stage with unregulated linear supply
  • Anti-Feedback circuit
  • Anti-Clipping circuit
  • EFX Loop with Active Send for Multi-Amp setups
  • Direct Power Amp In option
  • Sealed-box speaker tuning
Specifications:
Dimensions (H x W x D): 7.5" x 9.8" x 7.7"/192mm x 249mm x 196mm
Weight: 12 lbs./5.4kg
Peak Output: 130 dB-SPL (Peak) at 1 meter
Microphone Controls: Gain, Bass, Treble, Reverb
Instrument Controls: Gain, Bass, Treble, Reverb
Master Controls: Volume, Anti-Feedback Set
Misc Controls: Power On/Off, Phantom Power, Headphone/DI Output Level, Internal Speaker Mute, Voltage Select
ZT Lunchbox Acoustic Manual
Advanced Users Guide
Lunchbox White Paper
I really wanted to love this amp. It really light and small. I live and work in NYC and this amp would make my life so much easier. It sounds best with steel string acoustics. I felt that every other acoustic instrument that I used did not get the sound I was looking for. I tried it on my Johnny Smith,Gibson F and A style mandolins, acoustic steel strings, nylon classical and ES 175. It works pretty well with the 175. Wierdly it has too much mid range and the. EQ will not allow you to thin it out. I think they overcompensated electronically by over boosting the bottom range. It works for steel string acoustic . Too bad it's almost right but light weight isn't enough for me to give up sound. I own a Mini Brute,Mega Brute,Trace Elliot, and Jazz Kat Fender Princeton,Fender Concert, and Roland Streo Chorus 90. I am very picky.
Submitted by: Greg on 02/17/2013 01:58:37 PM
Pros: Small, light, plenty of power for a small venue, good reverb, two inputs, independent gain/tone adjustment
Cons: Cannot drive an external cabinet and its own speaker simultaneously
I ordered the ZT Lunchbox Acoustic not fully certain of what I'd receive. My practice amp was not sounding the way I wanted and I was tired of fiddling with my power mixer. I needed something that would allow me to practice with a clean sound, give me a microphone channel and some power. On paper, this looked to fit the bill. I have to say I was more than happily surprised. The sound from the 6.5" speaker was better than I imagined (especially on the low end) and when running the signal out to one of my PA speakers (15" cone with horn tweeter) the sound was impressive. The reverb is pleasant and lends itself well to a clean jazz sound. I have run the signal direct from a hollow-body electric, a nylon string guitar with preamp and both work well. I've also run a signal from a PC preamp/processor with no issues. A preamp, obviously, will give you more volume, but both work well for practice or small rooms. I wish it was a tad less expensive, but the portability and versatility are wonderful. ZT's next goal should be to allow it to drive its own speaker and an external cabinet simultaneously (like the standard Lunchbox amp) and consider batter power. An excellent amp.
Submitted by: Scott on 10/20/2011 12:44:47 PM
Nice box
I'd like to share a few of my first impressions with Lunchbox Acoustic. While I'm giving it a full 5 star rating it should be seen in context. Meaning it's great for what it is! I could've compared it to some higher end $700 and up amps and in that world it certainly wouldn't rate 5 stars. While I read and saw many glowing reviews amateur and pro alike I can't say this is a killer amp in all respects. For one I'm still to be convinced of it's power rating and high, clean headroom. It is clean but only to a certain point after which there is a slight but audible distortion. I'm trying to follow ZT recommendations for finding a clean sound and I'm still hopeful that I will find that golden spot. I've used it with solid body electric trying to achieve jazzy sound and oval hole Selmer copy with K&N elements under the floating bridge. And then there is what is at the same time it's biggest strength and one of the weaknesses: this amp represents the sound of your acoustic instrument pretty accurate to my ears. To high end audio purists that could not be a better achievement, however most people, in my opinion want their guitar amp to achieve "magic" and sweeten up the sound of their instrument through some clever EQuing. It seems to me that folks at ZT went the audio purist way and I give them thumbs up for that! The amp got completely different reactions from my friends when I played in public with it for the first time (using Parker fly guitar): from "wow it sounds great, clean but pretty warm" to "too clean, almost piercing". I asked for honest opinions from all of them. This could also be simple matter of seating positions, the guy who was somewhat brittle sat pretty much in amps direct path, others were more off-axis. I think the sound can be dialed in to my satisfaction though, after little more usage and experience if different situations. Bottom line is when you take is consideration it's size, power output and quality of sound I don't know of anything that can touch it. Anything out there that can compare in sound and power will be bigger or with much less power or much pricier. Anything that will flat out beat it with sound will have at least 8-10" speaker or array of smaller drivers and cost twice as much. So that is why it gets 5 stars from me.
Submitted by: Buco on 02/01/2011 07:59:51 AM
ZT LUNCHBOX ACOUSTIC CARRY BAG
ZT Amplifiers LUNCHBOX ACOUSTIC CARRY BAG
$35.00
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.017595 Seconds Memory Usage: 1.435768 Megabytes
