Schertler Unico X Acoustic Amplifier (Anthracite) Schertler Unico X Acoustic Amplifier (Anthracite) Schertler Offering a significantly improved power amp and speaker section, together with a crossover filter network, limiter and gain, the Schertler Unico X 5-channel combo amp provides 280W (123dB SPL) of bi-amplified analog power. Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers schertler-unico-x-amplifier-anthracite Unico X Wood 2756.00 DjangoBooks.com
Home / Amplification / Amplifiers / Schertler Amplifiers / Schertler Amps / Schertler Unico X Acoustic Amplifier (Anthracite)
Schertler UNICO X represents the state of the art in Swiss amplifier design, reflecting all the needs of the user. Offering a significantly improved power amp and speaker section, together with a crossover filter network, limiter and gain, this impressive 5-channel combo amp provides 280W (123dB SPL) of bi-amplified analog power.
UNICO X is equipped with a 1” dome tweeter and 10” woofer. It is designed with an optimized 2-way bass reflex construction. UNICO X is ideal for those seeking no-compromise acoustic instrument amplification in both live performance and studio situations. It delivers the wide low range typically needed for vocals or acoustic guitars, along with clarity and transparency. The five inputs can accommodate a variety of different setups, including an effect loop via the Aux Out.
UNICO X is available in a choice of wood or anthracite finishes.
SCHERTLER amps feature a high-end Class-A preamp with no integrated circuits and No Negative Feedback.
$2,756.00
Amp Specs
Weight 16.8 kg Dimensions 34.2 x 32.6 x 43.8 cm Frequency Response 40 to 20 kHz Sensitivity (1W/1m) @1 kHz 98 dB Power 280 W Pure analog power SPL Max 123 dB Speakers 1” dome tweeter, 10” woofer Box construction 12 mm birch BB laminated System - Format Bass reflex - Two way - Bi-amp Mic In connector XLR Mic In sensitivity -52 dB Mic In impedance 4.7 kΩ Instrument In connector 1/4" jack unbalanced Instrument In sensitivity -47 dB Instrument In impedance 820 kΩ Stereo In connector 1/8" jack stereo Stereo In sensitivity -10 dBu Stereo In impedance 40 kΩ Insert On master Line Out connector 1/4" jack Line out level 0 dBu Line Out impedance 200 Ω DI Out connector XLR DI Out level -∞ to +6 dBu DI Out impedance 180 Ω Aux Out connector 1/4" jack unbalanced Aux Out level 0 dBu Aux Out impedance 200 Ω Phones connector n.a. Phones level n.a. Phones impedance n.a. Phantom Power (nominal) 24 VDC (XLR) / 10 VDC (jack) Effect Spring-type digital reverb with decay
SMS Monitor Speaker Stand
Stand for monitor speakers.
$179.00 $129.00 (Save 28%)
Out Of Stock
Schertler S2 Stand
Monitor stand for SCHERTLER amps models JAM 100, JAM 150, David, Unico. Soft rubber rests pads firmly hold amps while adjustable leveling foot compensates for uneven floors.
$102.00
Unico Gig Bag
Gig bag Unico Amp.
$192.40
Outlaw Amp Ramp
$26.95
Volume Pedal
$101.40
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.023782 Seconds Memory Usage: 2.032059 Megabytes
