Schertler Tom PA System Wood
TOM is a 1000W (500+250+250) analog amplification system consisting of a compact active subwoofer and two passive satellites. The former Pocket Two system has been re-engineered for professional use, featuring an enhanced design and several new control features, such as a mono/stereo switch, for greater flexibility. The subwoofer is constructed using BJT technology, incorporating a linear power supply for excellent bass response and efficient stereo effect. Sub levels can be adjusted from -7dB to +2dB. Each satellite contains a passive crossover featuring a custom coil.
TOM has been specifically developed for use in medium to large sized indoor and outdoor venues, providing powerful coverage for a range of mobile sound reinforcement applications. Easy to transport and set up, the system is also highly effective for live performance situations, proving ideal for acoustic instrument amplification.
Insulated padded bags can be separately purchased for the system components, ensuring safe transportation and storage.
TIM & TOM are available in a choice of wood or anthracite finishes. The more delicate wood finish is perfect for studio or home use, blending with a range of room interiors. The anthracite finish is designed for performance and touring applications, where a more robust exterior finish is required.
Item: 6510
$4,107.00 $3,088.00 | Out of Stock | Stock Notification
Amp Specs
Schertler Teddy (Wood)
Specially designed to be the perfect on-stage partner, TEDDY provides the performing musician with 200W of power, without taking any of the limelight.
$1,944.80
Schertler 3pod Stand
Metal support for loudspeakers, with an air-cushion mechanism that guarantees a soft and safe height adjustment.
$89.95 $45.95 (Save 49%)
Schertler Tom Satellite Bags
Bags for Schertler Tom Satellite Speakers
$90.44 $68.00 (Save 25%)
Schertler Tom Sub Bag
Bags for Schertler Tom Sub Speaker
$117.04 $88.00 (Save 25%)
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.018302 / 1.588722]
