Schertler Tim PA System Wood Schertler Tim PA System Wood Schertler A full PA system from the leader in acoustic amplification! Arts & Entertainment schertler-tim-wood Tim 2088.00 DjangoBooks.com
TIM is a 600W (350 +125+125) analog amplification system consisting of a compact active subwoofer and two passive satellites. The former Pocket 1 system has been re-engineered for professional use, featuring an enhanced design and several new control features, such as a mono/stereo switch, for greater flexibility. The subwoofer is constructed using BJT technology, incorporating a linear power supply for excellent bass response and efficient stereo effect. Sub levels can be adjusted from -7dB to +2dB. Each satellite contains a passive crossover featuring a custom coil.
Easy to transport and set up in live performance situations, TIM is ideal for use with acoustic instruments and in jazz or DJ sets. The system also forms a highly efficient compact PA for use in small to medium sized venues such as piano bars, gyms, conference rooms or ballrooms.
Insulated padded bags can be separately purchased for the system components, ensuring safe transportation and storage.
TIM & TOM are available in a choice of wood or anthracite finishes. The more delicate wood finish is perfect for studio or home use, blending with a range of room interiors. The anthracite finish is designed for performance and touring applications, where a more robust exterior finish is required.
6510 - Schertler Tim PA System Wood
$2,777.00 $2,088.00 | Out Of Stock | Stock Notification
Amp Specs
Schertler Teddy (Wood)
Specially designed to be the perfect on-stage partner, TEDDY provides the performing musician with 200W of power, without taking any of the limelight.
$1,944.80
Schertler 3pod Stand
Metal support for loudspeakers, with an air-cushion mechanism that guarantees a soft and safe height adjustment.
$89.95 $45.95 (Save 49%)
Out Of Stock
Schertler Tim Satellite Bags
Bags for Schertler Tim Satellite Speakers
$90.44 $68.00 (Save 25%)
Out Of Stock
Schertler Tim Sub Bag
Bag for Schertler Tim Sub Speaker
$117.04 $88.00 (Save 25%)
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.033776 Seconds Memory Usage: 3.799911 Megabytes
