Schertler Roy Wood
An Acoustic Amplifier with all the Power and Flexibility of a PA System
The Schertler Roy is a powerful acoustic amplifier with 400W of power, 5 channels, and arguably the clearest, most natural sound of any acoustic amp on the market! This unit features two 8" woofers, a 1" horn, and a Class A preamp which will add warmth and clarity to your sound.
The Roy is Equipped with All the Inputs and Outputs You'll Need
The Schertler Roy has five instrument channels:  four channels have both XLR mic and 1/4" instrument inputs, while the fifth channel has just a 1/4" input. Both 48V and 10V phantom power is supplied to all inputs. A sixth channel has a mini stereo input for an MP3 player and a seventh channel has stereo inputs for the external effects loop. An insert plug is also included which can be used with Schertler's nondestructive side-chained volume pedal or any other dynamics processing device. The output section includes a Line Out, adjustable DI, a headphone jack, and an AUX out as well as a low cut filter and a mute switch.
Advanced Signal Processing is at Your Fingertips
The Schertler Roy features versatile EQ controls with Low, High, and Mid sweeps as well as parametric EQ for added control. The RESON control notches out feedback prone Low Mids, enabling mics or Schertler DYN pickups to achieve substantially more volume before feedback. The WARM button essentially emulates the tone of an AER amp by boosting Mids and cutting Highs, which smooths out quacky, harsh sounding piezo type pickups. An internal digital reverb with a decay control and a multi-effects unit (i.e. chorus, delay, flange, etc) is also included.
Schertler Roy Wood
Schertler Roy Wood
Item: 6500
$2,777.00 $2,088.00 | Out of Stock | Stock Notification
Amp Specs
Weight 22.2 kg (48.5lb)
Dimensions 35.7x41.5x51cm
Frequency Response 40 Hz to 20 kHz (+/-3dB)
Speakers 1” dome tweeter, 2x 8” woofer
Construction Birch laminated
Channels 7 indipendent channels
Inputs Mic In (channel 1-4) XLR
Instrument In (channel 3-5) 6.3mm Jack
Stereo In (channel 6-7) 3.5mm Jack and 6.3mm Jack
Insert (channel 1-4) and on master
Outputs DI, LINE, AUX and Insert (channel 1-4) and on master
Phantom Power 10V on Channel 3-5, 48V on Channel 1-4
Effect Digital reverb with Decay and parallel Multieffect
Preamp Class-A
Power 400W Bi-amplified
Schertler S4 Stand
Monitor stand for larger SCHERTLER amps and combos. Soft rubber rests pads firmly hold amps while adjustable leveling foot compensates for uneven floors.
$175.00
Schertler Roy Gig Bag
Gig bag for Schertler Roy Amp.
$156.94 $135.00 (Save 14%)
Outlaw Amp Ramp
$26.95
Shertler Roy Acoustic Amp
Pros: Sounds Great
Cons: Gig Bag not included
I purchased this for use as a mini PA for my band (a tro of guitar, vocals, and bass.) It's so much better sounding than any mini PAs a tried and much less expensive as well!
Submitted by Melissa on 08/02/2018 08:55:02 AM.
The Roy!
Wonderful sounding amp. The build quality is just stunning and it sounds fantastic!
Submitted by Sam B on 07/21/2018 04:19:20 PM.
Schertler Roy
Pros: 400W, 6 Channels, Class A Pre Amp
Cons: A little heavy
I ordered a Schertler Roy from DjangoBooks about a month ago and have been absolutely delighted with it! It has the power and versatility of a large PA without the hassle. The sound quality is fanatstic, easily the best sounding acoustic amp I've ever heard. And thanks to Michael at DjangoBooks for the great customer support and quick delivery.
Submitted by Bud on 06/27/2018 11:27:54 AM.
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.01999 / 2.128441]
