Schatten NR-2 Player National Biscuit Bridge Pickup Schatten NR-2 Player National Biscuit Bridge Pickup Schatten Design Schatten NR-2 Player is a passive pickup for National type resonator guitars. Arts & Entertainment > Musical Instrument Accessories > String Instrument Accessories schatten-nr-2-player NR-2 Player 119.95 DjangoBooks.com
Home / Amplification / Pickups / Schatten Design Pickups and Preamps / Resonator Guitar Pickups / Schatten NR-2 Player National Biscuit Bridge Pickup
Designed For 'National' Style Reso's - Pickup Attaches To The Saddle or The Top Of The Biscuit
The NR-2 series of pickups is our way of providing a really good sounding pickup that can be mounted quickly and easily to National style instruments without having to drill any holes for anything when installing the passive versions.
The Schatten NR-2 Player Biscuit Bridge Resonator Pickup is a really good sounding pickup that can be mounted quickly and easily to National style instruments. The NR-2 Player includes a standard chrome endpin jack that can be installed in the side or tailblock of the instrument.
The NR-2 Player is a passive pickup, no battery required. The output is sufficient to drive most amplifiers, but you may need a preamp or direct box if you are plugging into a PA system or mixer board, or running through effects pedals where a loss of signal can occur.
This pickup has been designed to operate properly and sound good without the use of a preamp when plugged into any 'normal' electric guitar amp. As with any pickup, the sound can be further enhanced and EQ'd with an outboard preamp. If you require the added ability to be able to plug directly into a P.A. or mixer on a regular or occasional basis and you don't wish to have an on board endpin jack preamp, then you may wish to add a preamp or direct box to your pickup system.
$129.95 $119.95 (Save 8%)
Schatten Mini-Pre
$75.95
$140.00 $89.00 (Save 36%)
Out Of Stock
$200.00 $135.00 (Save 33%)
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.012782 Seconds Memory Usage: 1.439674 Megabytes
