Schatten D-4 Std Player Appalachian Dulcimer Pickup Schatten D-4 Std Player Appalachian Dulcimer Pickup Schatten Design Schatten D-4 Std Player is a passive sensor that adheres to the soundboard of an Appalachian dulcimer. Arts & Entertainment > Musical Instrument Accessories > String Instrument Accessories schatten-d-3-std-player D-4 Std Player 119.95 DjangoBooks.com
Home / Amplification / Pickups / Schatten Design Pickups and Preamps / Other Instruments / Schatten D-4 Std Player Appalachian Dulcimer Pickup
Simple and Easy Installation
The D-4 Std. Player model dulcimer pickup is now available. It is an outstanding pickup that combines great sound with simple and quick installation......and best of all, for most installations you don't have to modify a thing on your dulcimer as no holes have to be drilled and no screws are used.
The D-4 Std. Dulcimer pickup mounts to the soundboard of any shape of dulcimer with a little bit of our special non-marring putty. A thin layer of the putty applied to the underside of the pickup attaches the piezo unit securely to the top of the instrument. The putty will not dry out and will not leave any residue on the instrument.
The D-4 Std. Player comes complete with a rosewood bodied 1/4" output jack assembly and is fully wired and ready to use. For most installations, the jack assembly mounts securely to the end block of the dulcimer with the supplied 3M VHB foam mounting tape so no holes need be drilled in the instrument.
$144.95 $119.95 (Save 17%)
Schatten Mini-Pre
$75.95
$140.00 $89.00 (Save 36%)
Out Of Stock
$200.00 $135.00 (Save 33%)
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013739 Seconds Memory Usage: 1.435806 Megabytes
