Schatten CH-1 Celtic Harp Pickup Schatten CH-1 Celtic Harp Pickup Schatten Design The new CH-1 is designed for use on smaller bodied Celtic harps having 28 strings or less. Arts & Entertainment > Musical Instrument Accessories > String Instrument Accessories schatten-ch-1 CH-3 Artist 119.95 DjangoBooks.com
The new CH-1 is designed for use on smaller bodied Celtic harps having 28 strings or less.  It provides a very simple solution to the problem of quickly and easily adding a pickup to a harp.
     The pickup sensor simply sticks to the soundboard next to the string strip, while the output jack assembly has a clip on its' back that allows it to easily clip to the edge of any sound port of the back of the harp.
     Up to 18 inches of the lead wire from the pickup sensor to the output jack stores right inside the jack assembly box - which keeps everything neat and tidy.
     The CH-1 can easily be moved from one harp to another - so one pickup can be used on more than one harp.
    The CH-1 is a passive pickup. It will work properly going straight into most normal electric guitar or bass  amplifiers. If you are going to go directly into a P.A. system, a preamp such as our Mini Pre acoustic preamp will be needed. This will allow you to use this pickup to its full potential no matter what you are plugging into - any type of amp or any PA system.
The CH-1 pickup system comes complete and ready to install. Installation of the pickup sensor is quite simple, as the unit adheres to the soundboard with our special mounting putty. The mounting of the output jack is equally easy as our new output jack assembly simply clips safely and securely to virtually any sound port opening.
   The pickup sensor is designed to be installed approximately one-third of the way up from the bass end of the soundboard.
       The transducer unit attaches to the soundboard with our special supplied putty. This putty provides a solid and secure mounting for the pickup but still allows for quick and easy removal of the system.
     Total installation time is normally a couple of minutes at the most. It's that easy.
$119.95
Schatten Mini-Pre
$75.95
$140.00 $89.00 (Save 36%)
Out Of Stock
$200.00 $135.00 (Save 33%)
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013912 Seconds Memory Usage: 1.440605 Megabytes
