Schatten S-4 Neo Schatten S-4 Neo Schatten Design Schatten S-4 Neo - for Selmer Maccaferri Gypsy Jazz Guitars Arts & Entertainment > Musical Instrument Accessories > String Instrument Accessories > Guitar Accessories > Acoustic Guitar Pickups schatten-S-4-Neo 6906 5.0 1
5 5
Very good product, sounds great and is very easy to install. As for the pricing, a bit high in a general sense but admittedly very fair within the world of manouche accessories, since by their nature they're niche products. If you need an aftermarket pickup for your Mac and don't have any luthiery skills (like me, lol), I definitely recommend the Schatten!
143.95 DjangoBooks.com
Schatten S-4 Neo
Schatten S-4 Neo
The S-4 Neo combines a pair of new S-4 sensors with Schatten's brand new Neo-Jack to provide excellent sound with a non-invasive jack installation. The sensors adhere to the top just behind the bridge and the Neo-Jack mounts just behind the tailpiece using two of the existing tailpiece mounting screws. There are no holes to drill. Total installation time is about 5 minutes.
The sensors for the S-4 mount easily with the supplied putty. Everything is prewired and ready to go. Placement of the sensors is directly over the bracing for the bridge box so response and feedback rejection are both excellent.
Any excess lead wire between the sensor and the Neo-Jack stores easily beneath the tailpiece. The only tool required for installation is a small phillips screwdriver that will be used to install the Neo-Jack.
The Neo-Jack provides a standard 1/4" output jack.
The passive S-4 Neo works perfectly well and sounds good when plugged straight into any decent quality guitar amp.  As with any pickup, the sound can be further enhanced with an outboard preamp. If you require the ability to plug directly into a P.A. or mixer then you may wish to add Schatten's Mini Pre belt clipable preamp.
$159.95 $143.95 (Save 10%)
Schatten S4 Neo passive pickup
Submitted by: Jon on 08/31/2021 02:05:18 PM
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.019006 Seconds Memory Usage: 1.893372 Megabytes
