Schaller Three on a Plate Tuners Schaller Three on a Plate Tuners Schaller Affordable Selmer style tuners from one of the world's best manufacturers. Arts & Entertainment schaller-three-on-a-plate 5052 129.00 DjangoBooks.com
Home / Accessories / Guitar Parts / Tuners / Schaller Three on a Plate Tuners
These are the standard tuners used by Dupont on his MD50 series guitars. They are a very reliable, low cost tuner made in Germany by one of the world's best manufacturers! They will fit on most Gypsy guitars, including Asian imports.
PROFESSIONAL INSTALLATION REQUIRED:
The shafts must be ground down as they are slightly too long for a standard Selmer headstock. Also, the headstock needs the hole for the shafts to be tapered.
Gear ratio 1:16.
The worm gears and shafts used in our acoustic guitar machine heads are precision-manufactured and mounted with precisely the correct spacing on a warp-proof baseplate.
The bearings are made of extremely gliding material, meaning that all moving components work absolutely free of friction and wear. You can tune your guitar easily and precisely, without any slack and without a high turning resistance.
All parts are precision-crafted and surface-finished, the self-locking drive ensures an even, delicate and steady tuning.
All string posts are made of high-grade brass and fitted into the housing with utmost precision, ensuring the best possible tuning accuracy and wear resistance.
$129.00
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013293 Seconds Memory Usage: 1.340897 Megabytes
