Roland DR 50 Dynamic Microphone Roland DR 50 Dynamic Microphone Roland Roland DR 50 Dynamic Microphone Electronics > Audio > Audio Components > Microphones roland-dr-50 DR-50 150.00 DjangoBooks.com
Home / Amplification / Pickups / Roland Microphones / Roland DR 50 Dynamic Microphone
The Roland DR-50 is decidedly a pro-quality microphone. It has a hypercardioid pattern,. enhanced shock-absorption to reduce handling noise, and a double windscreen to minimize breath noise
Professional hand-held mic
Hypercardioid polar pattern
90Hz-16kHz frequency response
Enhanced shock-absorption and reduced mic handling noise
Double-screen structure to reduce breath noise
Includes stand clamp, threaded adapter, 15' cable, and protective pouch
6905 - Roland DR 50 Dynamic Microphone
$219.00 $150.00 | Out Of Stock | Stock Notification
Roland AC 33 ACOUSTIC AMPLIFIER
The Roland AC 33 is light weight, loud, and flexible and can run on either AC or battery power. At only 10.5 lbs, this little powerhouse will follow you anywhere and deliver the sound reinforcement you need.
$599.99 $449.99 (Save 25%)
Out Of Stock
Roland AC 60 ACOUSTIC AMPLIFIER
The Roland AC 60 acoustic amplifier is small, powerful, and loaded with effects.
$749.99 $499.99 (Save 33%)
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.037186 Seconds Memory Usage: 4.997734 Megabytes
