Phil Jones Bass Suitcase Compact with Cover Red Phil Jones Bass Suitcase Compact with Cover Red Phil Jones Pure Sound This model is based on the no compromise performance of the original PJB Suitcase. Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers phil-jones-suitcase-compact-bg-400-red BG-400 1199.99 DjangoBooks.com
Home / Amplification / Amplifiers / Phil Jones Bass / Phil Jones Bass Combos / Phil Jones Bass Suitcase Compact with Cover Red
PHIL JONES BASS
It is more powerful by physically smaller; in fact the same size as our Compact 4 enclosure. It has an incredible punch sound cutting through air as "a knife through butter" but with a solid and powerful low end response normally associated with a much larger combo.
It features a two-channel pre-amp with our unique 3 band EQ. Simple to find "your sound", the EQ sound has amazing control and transparency that allows you to unmistakably hear the true characters of your own playing and instrument.
In the heart of this amp lies a formidable ultra-energy power supply. It feeds an efficient class D power amplifier which utilizes almost 95% of this energy to drive the four internal PJB Piranha speakers.
The Suitcase Compact puts out a healthy 300 watts RMS onto its own speakers. Adding a Compact 4 cabinet it becomes 500 watts, and adding a Compact 8 it becomes 575 watts.
The future of amps is trending to "smaller and better" but with the Suitcse Compact bass combo, the future is here now!
$1,325.00 $1,199.99 (Save 9%)
Amp Specs
Power: 300W (RMS), 500W (RMS) with ext. Compact 4 speakers
Speakers: 4×5″ "Piranha" Type B
Controls: 2x (level selector, Volume, 3 Band EQ), Limiter w/ on/off switch, Master Volume
Jacks: 2x Input (1/4″ phone)
Headphone Out, DI out, FX Send/Return, Tuner Out, Preamp Out, Ext. Speaker Out (8 Ohm/Speakon)
Dimensions (WxDxH): 14″x12″x14″
Net Weight: 40 lbs
BI-12 Bass Instrument Cable
$109.99 $99.99 (Save 9%)
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.022986 Seconds Memory Usage: 2.310921 Megabytes
