Home / Phil Jones Bass 24-B Enclosure
PHIL JONES BASS
Earthquake-like intensity. Shocking fidelity. If you a large format player, you are going to hear yourself in a brand new way with the 8T & 24B
cabinets.
Dangerous power? Indeed. The 8T & 24B can handle up to 3200W but with absolute authority, clarity and purity. With harmonics so startling and headroom so massive, the audience may need to be resuscitated. And you may need a fatter contract. With regular cabinets, the bass player is the glue. With thirty-two 5” Piranha drivers, the bass player is rubber cement. Simply put, there is nothing like it.
“Wow, this is a great cabinet! Fantastic” – 8T & 24B Registered Owners
Type
Full size
Bass loudspeaker
Speakon Connectors
Sensitivity
105dB/W/M
Impedance
6ohm
Frequency Response
25Hz - 15KHz
Size
24.5 x 35 x 19.5
Accessories
Allen key
Nylon cover
Castors x 4
Power Output
2400W
Speakers
24 x PJB PIRANHA TYPE A
Volts
Not Applicable
Item: 6900
$2,499.00 $2,149.99 | Out of Stock | Stock Notification
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.016323 / 1.273201]
