Phil Jones Bass 16-B Enclosure Phil Jones Bass 16-B Enclosure Default Manufacturer Phil Jones Pure Sound 16-B Enclosure Arts & Entertainment phil-jones-pure-sound-16-b-enclosure 6900 1149.99 DjangoBooks.com
Home / Phil Jones Bass 16-B Enclosure
PHIL JONES BASS
High sound pressure levels can really be taxing on speaker cabinets. Power compression can occur when you want to really crank your rig, but it doesn’t deliver the extra amount of power you need…which affects the
way you play. Not anymore.
Uncompromising power? Indeed. The 8T & 16B can handle up to 2400W but with purity, clarity and high fidelity. Slapper? You probably haven't really heard just how much energy you put on those strings. These cabinets deliver unprecedented dynamics with blinding accuracy. Startling high, powerful mids and downright righteous lows, the 8T & 16B will amplify your
sound...and your style.
Type
Full size
Bass loudspeaker
Speakon Connectors
Sensitivity
108dB/W/M
Impedance
8ohm
Frequency Response
30Hz - 15KHz
Size
24.5 x 27.5 x 19.5
Accessories
Allen key
Nylon cover
Castors x 4
Power Output
1600W
Speakers
16 x PJB PIRANHA TYPE A
Volts
Not Applicable Image shown with 8-T (top) and 16-B (bottom)
6900 - Phil Jones Bass 16-B Enclosure
$1,649.00 $1,149.99 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.011662 Seconds Memory Usage: 1.181503 Megabytes
