Home / Phil Jones Pure Sound PA Systems / Phil Jones LS-1200
Phil Jones LS-1200
PHIL JONES BASS
The LS-1200 is double the output of the LS-600, and itvirtually takes up the same floor space. It uses two NEOPOWER 10 inch woofers and twelve NEOPOWER 3.5 inch liquid cooled speaker units. This system would be the ultimate compact PA for large bands or small combos. The LS-1200 will fill an auditorium with clean transparent, full-range sound with ease. Used in multi channel sound, it is an excellent cinema sound system outperforming today’s conventional horn loaded systems with
stellar clarity on dialogue, music and sound effects.
Type12 x 3.5" drivers, 2 x 10" woofers
Sensitivity101dB/W/M
Impedance4 ohm
Frequency Response40Hz - 20KHz
Power1200W
SizeTower: 5 x 49.3 x 12inch
Subwoofer: 14.9 x 27.1 x 17.7
Speakers12 x 3.5" drivers, 2 x 10" woofers
Net Weight31.3 lbs/50.6 lbs
Phil Jones LS-1200
Phil Jones LS-1200
Item: 6900
$9,995.00 $6,995.99 | Out of Stock | Stock Notification
Briefcase Amp Cover
Briefcase Amp Cover
$29.99
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.036205 / 5.442757]
