Phil Jones Bass Briefcase Signature with Cover Phil Jones Bass Briefcase Signature with Cover Phil Jones Pure Sound Exuding in luxury, like a fine musical instrument, the Briefcase Signature cabinet is hand polished to a mirror finish in Tobacco Sunburst, Sapele wood. Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers phil-jones-briefcase-signature BBC Signature 1495.99 DjangoBooks.com
Home / Phil Jones Bass Briefcase Signature with Cover
PHIL JONES BASS
The BRIEFCASE is not your usual combo-practice amp. The most striking difference between this combo and others is that it features an extremely clean and powerful amplifier and full range compact speaker that can run on AC or DC power. It can accept voltages from 100 to 240 volts by using the voltage selector switch, can run on an internal lead acid gel battery (not supplied) or even an external 12V DC source such as a automotive starting battery.
Though it is a dedicated bass amplifier, this unit will work ideally for other instruments, particularly acoustic variety due to its natural hi-fi sound character. This unit is also an ideal upright bass amplifier.
The two 5 inch proprietary PJB drivers have been acoustically optimally loaded by precise computer analysis to provide a full-range, dynamic sound that can play down to an open E string with ease. The BRIEFCASE can handle an open B string if not too much bass boost is used.
6900 - Phil Jones Bass Briefcase Signature with Cover
$1,659.00 $1,495.99 | Out Of Stock | Stock Notification
Amp Specs
Power: 150 watt RMS
Speaker: 2x 5″ PJB "Piranha" Type C
Controls: Volume, 5 band EQ, Limiter with On/off switch
Power switch
Input: headphone out, Pre-amp out, speaker out, DI out, AC input, DC input
Dimensions (WxDxH): 6.7″x17.3″x15.5″
Net Weight: 31 lbs
Soft cover included
(Battery not included)
BI-12 Bass Instrument Cable
$109.99 $99.99 (Save 9%)
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.01538 Seconds Memory Usage: 1.692993 Megabytes
