Home / Amplification / Amplifiers / Phil Jones Bass / Phil Jones Bass Combos / Phil Jones Bass BASS CUB II BG-110 Red
The Bass Cub 2 BG-110 is the latest version of the popular PJB Bass Cub BG-100 and replaces that model.The Bass Cub is 100 watts of pure tone in a “shoebox” size package. It is so light, that it can be lifted with one finger!
Over the past 2 years, Phil Jones Bass has researched into a better amplifier to power the bass Cub. As a result The Bass Cub 2 has far greater transient attack from improved loudspeaker cone acceleration, greater dynamic range, and lower harmonic distortion. The improved amplifier design also has an upgraded power supply able to provide a rock-solid stable voltage and current to feed the amplifier.
We didn’t stop there; we researched into a better loudspeaker, specially engineered for the BASS CUB 2 that gives a wider and smoother frequency response using our unique “Chrome-Dome” technology.
The new Bass Cub has an exciting, wilder character like putting a turbocharger on an engine. It will free your bass playing with greater increased headroom, and speed to capture every nuance of your playing from gentle fingerstyle to hardcore slapping.
Two independent channels can accept two instruments or one microphone. It also has a stereo input for Drum machine or iPod/MP3 player. Practicing can be done with the 2 internal speakers or headphones.
$729.99 $699.99 (Save 4%)
Amp Specs
Amplifier
110 watts class D amplifier with digital switch-mode power supply.
Dimensions: 12”W x 11”D x 7.8”H
Weight: 15.5 lbs
Soft Cover Included
Signal to Noise Ratio
≥ 85 dB(A) (EQ off, Volume on Full.)
Impedance
High Input: >2MΩ/22pF
Low Input: >100KΩ/22pF
Line Input: >40KΩ
Pre Amp Line Out: < 2KΩ
Bal. Out: <200Ω
Levels
High Input: 10mV-1.5V
Low Input: 20mV-4.5V
Tuner Out:1.2V
Pre Amp Out: 1.2V
Bal. Line Out: Typical 500mV
Protection Circuits
1. AC line filter.
2. Slow-blow Fuse: 5A / 250V.
3. Loudspeaker Short-Circuit Protection.
4. DC Output Protection.
Speaker
Computer Optimized Vented Enclosure
Speaker Frequency Response: 60Hz -15KHz
Speaker Compliment: 2 x 5inch proprietary, extended-range drivers
Speaker Sensitivity: 91dB/W/M
Internal Speaker Impedance: 4 Ohms
Included Parts
6 ft AC Power Cord
Soft Cover
BI-12 Bass Instrument Cable
$109.99 $99.99 (Save 9%)
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.018086 / 1.497162]
