Home / Amplification / Amplifiers / Phil Jones Bass / Phil Jones Bass Heads, Amps, and Preamps / Phil Jones Bass BigHead Pro Headphone Ampliifer
PHIL JONES BASS
Expand your practice and recording rig with this versatile, portable unit.
Phil Jones Bass has introduced a high-performance, multi-function headphone amplifier/digital audio interface: the Bighead Pro (Model HA-2). The HA-2 is the second model in the Bighead series and is a step up model of the popular HA-1 Bighead with added technology and features. The HA-2 is a high-resolution, USB audio interface that supports PCM playback with up to 384 KHz sample rate/24 bit resolution, DSD64 and DSD128. On DSD playback, sample rates of 2.822MHz and 5.644 MHz are supported, making it the ideal choice for musicians and engineers that desire high performance and the purest sound quality.
It is a rechargeable lithium ion dynamo that is ideal for use in practice or recording situations. It also functions as a headphone booster amp as well as a preamp to drive powered amplifiers. The HA-2 has both passive and active instrument inputs with a 2 band EQ that is ideal for guitar and bass yet versatile enough for use with other instruments.
Other features include master volume, input gain, treble/bass for instrument input signal, Headphone jack, Line out, Input, aux input, micro USB for battery charge and digital interface, frequency response 10Hz-40KHz. The dimensions are (WxDxH) 3” x 5.9” x 0.9” and it weighs 0.6 lb. A soft bag, micro USB cable and 3.5 jack stereo signal cable are included.
$429.99 $399.99 (Save 7%)
Amp Specs
Bighead Pro Headphone Amplifier and Audio Interface Specifications:
  • High-resolution USB audio interface supports PCM playback with up to 384KHz sample rate /24bit resolution, DSD64 and DSD128
  • Headphone power output: 300mW per channel
  • Headphone impedance: 16-64 OHMS
  • Frequency response: 10Hz-40KHz
  • Controls: Master Volume, Input Gain, Treble/Bass for Instrument Input Signal,
  • Jack: Headphone (3.5mm stereo mini)
  • Line Out (1/4" Phone), Input (1/4" Phone), AUX Input (3.5mm stereo mini),
  • Micro USB for battery charge and digital signal Interface
  • Dimensions (WxDxH): 3" x 5.9" x 0.9" (75 x 149 x 24 mm)
  • Weight: 0.6 lb. (290 grams)
  • Includes: Soft bag, micro USB cable and 3.5mm jack stereo signal cable
Phil Jones Bass H-850 High Performance Stereo Headphones
Audiophile headphones from Phil Jones!
$119.00
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.031945 / 2.774712]
