LR Baggs Venue DI Preamp LR Baggs Venue DI Preamp LR Baggs LR Baggs Venue DI Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers l-r-baggs-venue-di VENUE DI 329.00 DjangoBooks.com
Home / Amplification / Pickups / LR Baggs Pickups and Preamps / LR Baggs Venue DI Preamp
The LR Baggs Venue DI Direct Box offers a discrete acoustic guitar preamp. It combines a transformer-coupled DI output for maximum isolation, an EQ specifically tuned for acoustic guitars, a variable-boost control to complement your playing styles, and a chromatic digital tuner to help you stay in tune. Combining features from at least three stompboxes into one pro box, the LR Baggs Venue D.I. brings a new level of fidelity, confidence, and usefulness to performing acoustic musicians. The Venue D.I. is one of the most
comprehensive and best-sounding tools ever to tame the surliest stage.
1/4" input Input Impedance 10 mOhms Preamp Gain -12dB to +26dB Input Level -25dBv to +1.8dBv (.053Vrms to 1.23Vrms) EQ Notch -21dB, sweepable from 60Hz to 320Hz, 1/8 Octave Bass +/- 12dB @ 90Hz Lo Mid +/- 12dB @ 250Hz, sweepable from 100Hz to 500Hz Hi Mid +/- 12dB @ 1kHz, sweepable from 500Hz to 2.8kHz Presence +/- 12dB @ 3kHz Treble +/- 12dB @ 10kHz Effects Loops Send Level 0 dBv (0.707Vrms) Output impedance 600 Ohms Return level 0dBv (0.707Vrms) Maximum before clipping Input impedance 80 kOhms D.I Out Output level -1dBv (0.88Vrms) Balanced Line Out Output level -1dBv (0.88Vrms) Un-balanced Output impedance 200 Ohms
LR Baggs Venue DI Direct Box Features:
  • High-end audio transformer coupled XLR for full immunity from ground loops
  • 100% Discrete circuitry and EQ for sweet transparent and ultra quiet sound
  • Adjustable gain to handle most passive and active inputs
  • Garret Null notch filter to non-destructively handle feedback
  • Full chromatic tuner with footswitch mute/tune function
  • Bomber construction with metal shaft potentiometers
  • Phase inversion for best sound and feedback control
  • Works with 9V battery or DC adapter (not included)
  • Tunable low and high mid controls
  • Adjustable solo boost foot switch control
  • Real VU meter to accurately set gain
  • 4-segment battery status gauge
  • Series effect loop
Clean up your stage and your sound with the Venue DI box.
6905 - LR Baggs Venue DI Preamp
$399.00 $329.00 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.017959 Seconds Memory Usage: 1.819839 Megabytes
