JAZZKAT - TOMKAT II AMPLIFIER NEW 200W VERSION! JAZZKAT - TOMKAT II AMPLIFIER NEW 200W VERSION! Jazzkat JAZZKAT - TOMKAT II AMPLIFIER NEW 200W VERSION! Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers jazzkat-tomkat Tomkat II 5.0 1
5 5
I took your amp and tested it with my equipment. Your amp allows the true sound of the guitar to be heard. It's perfect!
950.00 DjangoBooks.com
Home / JazzKat Amplifiers / JAZZKAT - TOMKAT II AMPLIFIER NEW 200W VERSION!
The TomKat delivers the warm, pure tone of your instrument with
unprecedented accuracy and headroom.
The TomKat’s superb sound and incredible versatility are
unmatched anywhere near its size and weight! It’s has the sound
and the size you’ve been looking for. Weighs only 16 lbs.
200 watts RMS delivers powerful sound without compression
Precision-tuned enclosure with full-range two-way speaker
system
6700 - JAZZKAT - TOMKAT II AMPLIFIER NEW 200W VERSION!
$1,499.00 $950.00 | Out Of Stock | Stock Notification
Amp Specs
Two input channels
5 Band EQs
Speaker controls
Headphone jack
Ext. Spkr. Jack
Send / Return
120/240 Volts
16 digital effects
Lead Free
Light Weight
Specifications
Output: 200 watts RMS
Enclosure Type: Thiele-Small-alignment, optimally-vented
Driver Complement: 10-inch woofer and 1-inch dome tweeter
Channel 1 Input: 1/4-inch unbalanced high-impedance
Channel 1 Controls: Gain, 10dB Pad,
80Hz, 250Hz, 800Hz, 2.5KHz, 8KHz
Channel 2 Input: 3-pin XLR-type / 1/4-inch "combo" jack
Channel 2 Controls: Gain, 80Hz, 250Hz, 800Hz, 2.5KHz, 8KHz
Master Controls: Master Output Level, Effects Gain, Effect
Program, Channel Selector Switch
Ext. Spkr Output / Impedance: 1/4-inch jack / 8 ohms
Line Outputs: 3-pin XLR-type and 1/4-inch unbalanced
Operating Voltage: 120 or 240 volts, switch-selectable
Size (H x W x D): 15 x 15 x 9 inches
(38 x 38 x 23 cm)
Weight: 16 lbs
Tweeter Control—3 way switch
Tweeter Control—Phase Switch
Up—Full / Middle—Off / Down—-3dB
Feedback Reduction
Digital Effects Menu
Stereo Delay Slap Back Delay
Reverb Chapel Reverb Spring
Echo Chorus
Room 1 Reverb Church
Early Reflection Reverb Big Ambience Reverb
Reverse Reverb Gated Reverb
Phaser Flanger
Small Hall Reverb Big Hall Reverb
Tomkat II Manual
Great Amp!
Pros: Lots of power, light weight
Cons: Miss the tweed version!
Submitted by: Les Paul on 11/05/2013 09:14:29 AM
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.012375 Seconds Memory Usage: 1.355659 Megabytes
