JAZZKAT BLUESKAT AMPLIFIER JAZZKAT BLUESKAT AMPLIFIER Default Manufacturer JAZZKAT BLUESKAT AMPLIFIER FREE SHIPPING!!! Arts & Entertainment jazzkat-blueskat 6700 899.00 DjangoBooks.com
Home / No Show / JAZZKAT BLUESKAT AMPLIFIER
Whether you play Delta, Slide, Texas or Fusion, the BluesKatTM can provide you with the power and sound that the artist and audience will
love.
With a redesigned cabinet and advanced tube circuitry on channel one you can design the sound that best fits your music style. It doesn't matter whether it is a single coil pickup or the hottest in humbuckers, dialing
in the sound is a dream with the BluesKatTM EQ.
Using a high efficiency Eminence speaker, voiced for Blues, allows the amp to fully utilize its over 100 watts of power. The advanced ported tuned cabinet allows for full frequency range of the guitar to be heard
in a way other cabinets can't compare.
Adding an extension speaker jack gives the player the opportunity to add extension speakers to the main combo cabinet, increasing the sound field
so you can be heard all over the stage.
Need to practice at home without disturbing the rest of the family. Just plug in you headphones and the main speaker is turned off so you can practice for hours with that great sound in your ears.
Spec:
  • 1 12AX7 Tube on Channel 1 – Switchable on/off with an ON LED
  • 1 - 10” Celestion Speaker
  • 2 Channels
  • Channel 1 – Gain, Bass, Mid, Treble, 1/4” Phone Plug
  • Channel 2 – Gain, Bass, Mid, Treble, Combo Plug (1/4” Phone or XLR)
  •  20lbs
  • 125 Watts/RMS (8 Ohms)
  • 16 Digital Effects with separate Level Control
  •  Effects assignment switch – Channel 1 / Channel 2 /  Both
  •  Extension Speaker Jack (8 – 16 Ohms)
  • Headphone Jack
  • Line Out – XLR and ¼” Phone
  • Line Send / Return
  • Switchable power supply 120/240V
  • Top Handle
  • Advanced Sound Engineering Ported Tuned Cabinet
  • H 15” X W 12” X D 11”
  • ROHS Certified
6700 - JAZZKAT BLUESKAT AMPLIFIER
$999.00 $899.00 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.017659 Seconds Memory Usage: 1.896118 Megabytes
