1968 Jacques Favino Enrico Macias 1968 Jacques Favino Enrico Macias Favino Very rare, early example of Favino's most prestigious model! Arts & Entertainment jacques-favino-oval-hole-macias-96 Enrico Macias 14000.00 DjangoBooks.com
Home / Guitars / Gypsy Jazz Guitars: European and North American / 1968 Jacques Favino Enrico Macias
This is it! The highly coveted and nearly impossible to find Enrico Macias model Favino!! Serial #96, built in 1968.
The Enrico Macias model was named for the famous Algerian/French singer who gained stardom via a unique style that mixes Algerian al Andalous, Flamenco, and 70's era pop.
https://www.djangobooks.com/photos/favino187_crop.jpg
This model features maple back and sides, and a shorter 670mm Selmer scale length (most Favinos have a 675mm scale).
This is the earliest Macias model I've seen. Unlike the later models (which have block MOP fingerboard inlays), this one has standard MOP dot markers. Looks similar to the Maple Favino Bireli Lagrene played in his youth!
A number of famous Gypsy guitarists have played maple Favinos over the years. Bireli Largene played one in his teens and used it recently on the CD It's Alright with Me . Sounds amazing! Moreno and Mondine Garcia have also used maple bodied Macias style Favinos throughout their careers.
As mentioned earlier, the Macias features maple back and sides. The guitar has a three piece maple neck and snazzy ivoroid binding. It has the original SB tuners and nickel tailpiece.
This instrument is in very good condition. It plays easily with slinky 2.8mm action. The frets have some mild wear and the tailpiece has a fair amount of corrosion. There are two small cracks in-between the soundhole and the fingerboard, which is pretty typical for Selmer type guitars of this age. There is a small cleat underneath the treble side crack. There also appears to be another cleat underneath the cutaway area of the top, although there is no visible crack there. The guitar once had a bigtone and the endpin jack is still there, although the bigtone is gone. A small hole was plugged in the side of the cutaway. There is a small screw hole on the bottom of the heel for a strap button which is no longer there.
The tone of this instrument is simply glorious! It has the character and refinement that only age can produce along with the bark that Favino is famous for. More balanced than a typical Favino, this Macias model has the midrange fullness one would expect yet it's not overly dark or nasal. Single notes are snappy and crisp, with a lot of body while chords are wonderfully complex yet clear. Just one note immediately evokes late nite Gypsy jams around the campfire or the smoke filled cafes of Paris. There's no doubt, they don't build them like this anymore!
This is the CASH price...add 3% if you'd like to pay with a credit card
$14,000.00
Item Options
Install Clear Pick Guard ($60.00)
Install High Quality Ebony Tailpiece Ins ($40.00)
No Pickup
Dupont Bigtone ($480.00)
K and K Pure Maccaferri ($280.00)
K and K Definity System ($240.00)
Schatten HFN-S2 Pickup ($245.00)
Schatten HFN-S2 Pickup Artist (Includes Pre Amp) ($295.00)
Schatten HFN-S2 Pickup Artist Plus 1 (Includes Pre Amp and 1 Thumbwheel Control) ($305.00)
Schatten HFN-S2 Pickup Artist Plus 2 (Includes Pre Amp and 2 Thumbwheel Controls ($310.00)
Would you like to upgrade your guitars tuners?
No upgrade
Install Schaller Three on a Plate Tuners ($229.00)
Install Saga Deluxe Tuners ($175.00)
Install DR Brass Tuners ($495.00)
Install AG Brass Tuners ($320.00)
Argentine Strings (1 set): 1510
$11.00
$360.00
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.019458 Seconds Memory Usage: 2.126343 Megabytes
