Ibanez Artstar AS2000 Brown Sunburst Ibanez Artstar AS2000 Brown Sunburst Ibanez Very comfortable, easy playing, feedback resistant model that's great for many styles! Arts & Entertainment > Hobbies & Creative Arts > Musical Instruments > String Instruments > Guitars > Acoustic Guitars ibanez-AS2000BS AS2000BS 2399.00 DjangoBooks.com
Home / Guitars / Archtop Guitars / Ibanez Archtop Guitars / Ibanez Artstar AS2000 Brown Sunburst
The Perfect Crossover Guitar
If you’ve always played a solidbody electric, then adjusting to the ergonomics of a full-sized semi-hollowbody can be challenging. That’s why Ibanez created the AS2000. One of the smallest guitars in the Artstar line, the AS2000 showcases all the traits that one looks for in a semi-hollow; meanwhile, it boasts the comfort of a solidbody. The vintage tone has a healthy amount of warmth with a clean attack and enough sustain to rival your bass player. The body is made with figured anigre for a resonant timbre and good looks, and there are classic sounds to explore, thanks to Super 58 humbucking pickups. A tune-o-matic bridge and stop tailpiece provides excellent tuning stability. Finally, your fingers will appreciate the silky-smooth ebony fingerboard and generous carve of the 3-piece mahogany/maple neck. What’s more to say? Grab an AS2000 and experience the magic for yourself.
Super 58 pickups lend a pure, vintage tone
The Artstar AS2000 has a vintage voice, courtesy of the two Super 58 humbuckers. The Alnico III magnets and winding technique yield a vintage-style sound that sounds like the semi-hollows of yore. And for an extra helping of sustain, the pickups are mounted directly in the center block. Equipped with a Tri-sound switch to unlock three different pickup “voices," the Super 58 humbuckers can be used in series, parallel, and single-coil operation.
Sounds great and fights feedback
The figured anigre top, back, and sides of the AS2000 grab the eye instantly. But this guitar isn’t just a beauty. The semi-hollow body has a thick sound block that resists any tendency toward feedback. While most semi-hollows absolutely wail at higher volumes, it’s easy to keep the AS2000 smooth and velvety at high volumes. Plus, to provide the definition you need, Ibanez uses a bone nut. Combined with two Super 58 humbucking pickups, the AS2000 will dial in an expressive, rich tone.
Silky-smooth playing experience
When you take your AS2000 for your first test drive, you’ll be astonished by its neck. This oil-finished 3-piece neck is in a league of its own. The AM Artstar neck carve leaves just enough wood between your fingers for an old-school feel with performance fit for a new-school axe. The neck doesn’t just feel like silk to play; it’s strong, too. The neck’s maple ply is treated with Ibanez’s S-Tech wood-roasting technique to relieve weight and increase stability in the same process. Take it from us: the Ibanez Artstar AS2000's silky action and stability will impress you for years and years to come.
$3,466.65 $2,399.00 (Save 31%)
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.019763 Seconds Memory Usage: 2.282249 Megabytes
