Henriksen The Bud Head Henriksen The Bud Head Henriksen All the tone, power and features of The Bud are now available in package that’s just over 3 lbs! Arts & Entertainment henriksen-the-bud-head The Bud Head 899.00 DjangoBooks.com
Whether you’re looking for a pedalboard amp, an amp head, or a powered 2-channel DI, the new Bud Head is for you. The Bud amplifier has become the go-to amp when it comes to quality tone, power and versatility, offering truly gig-able utility in the smallest possible package.  Now you can pack all of that in your gig bag with the new Bud Head! It has the same 2-channel pre-amp as The Bud, the same power, but does not require a speaker to be attached so you can go straight to the house system, powered monitor or recording interface, or use it to power a speaker cabinet of your choice.
The Bud amplifiers are designed to offer the highest quality tone for BOTH electric and acoustic instruments that you’d expect from a studio situation, with enough volume to cover almost any gig. Henriksen Amplifiers is all about tone first, the incredibly portable size and feature set of The Bud were developed around the sound, not the other way around and you can definitely hear the difference.  Our pre-amp, from input to output, is designed using the highest grade audio components. We offer a 5-band EQ with carefully chosen center frequencies which were fine-tuned by ear to meet the demands of different playing environments using the widest possible array of musical instruments.  We give you two identical pre-amps, each with independent EQ and reverb and actual 48 volt phantom power, and an auxiliary input on each channel so that whatever you are using it for can be EQ’d separately from your instrument signal.
6905 - Henriksen The Bud Head
$1,065.00 $899.00 | Out Of Stock | Stock Notification
Specs
Size: 11" X 9" X 3", 7 lbs.
Controls: Volume, 5-band graphic equalizer, reverb with on/off switch and wet/dry mix control per channel.
Power: Maximum power is 160 watts at 4 ohms.
Warranty: Full 2 year warranty (see details on warranty page).
Line Out: Each channel has independent line out.
Speaker outputs: Two parallel 1/4" speaker jacks.
230v/115v Selector Switch: Yes
Henriksen The Ray Extension Cabinet
The smoothest, broadest and flattest frequency response cabinet you can find in a 10 lb package!
$799.00 $699.00 (Save 13%)
Out Of Stock
Henriksen JazzAmp Ten Cabinet
10″ Extension Cabinet with extended range tweeter.
$799.00 $599.00 (Save 25%)
Out Of Stock
Henriksen JazzAmp Twelve Cabinet
12″ Extension Cabinet with extended range tweeter.
$929.00 $699.00 (Save 25%)
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.024624 Seconds Memory Usage: 1.981926 Megabytes
