Henriksen JazzAmp 112 Henriksen JazzAmp 112 Henriksen Classic jazz tone in a lightweight cabinet! Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers henriksen-jazzamp-12-reverb-combo 112 949.00 DjangoBooks.com
Home / Henriksen JazzAmp 112
The JazzAmpTM 112 provides clear jazz tone with a deep, resonant presence. The 112 is ideal for guitarists who require more low frequency handling for playing a lot of walking bass lines or playing a 7-string guitar. The cabinet is designed for use with both guitar and bass, and will handle most upright bass pickups without the need for a separate preamp.
6905 - Henriksen JazzAmp 112
$1,265.00 $949.00 | Out Of Stock | Stock Notification
Amp Specs
Size:14" x 15 " x 13", 32 lbs.
Controls: Volume, 5-band graphic equalizer, reverb with on/off switch and wet/dry mix control.
Power: Maximum power on the JazzAmpTM 112 is 160 watts at 4 ohms (this requires an extension cabinet). As shipped with a single 8 ohm speaker it delivers 120 watts.
Speaker: Eminence® Beta-A 12.
Construction: 11-ply Finland Birch, steel chassis, Tolex covering with metal corners.
Warranty: Full 2 year warranty (see details on warranty page).
Line Out: Yes
Extension Speaker Jack: Yes (must be an 8 ohm speaker cabinet)
230v/115v Selector Switch: Yes
Henriksen JazzAmp 312 Gig Bag
Heavy duty padded gig bag for carrying your JazzAmpTM 312 around town. The front pocket is large enough for music books, pedals, cables and more. Click on the images to the right for a larger view.
$119.00
Out Of Stock
Henriksen JazzAmp 312 Pocketed Slip Cover
Heavy duty cover with side pocket for your JazzAmpTM 312. The pocket holds music, cables, and even a pedal or two.
$49.00
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.016677 Seconds Memory Usage: 1.802589 Megabytes
