Henriksen JazzAmp 110 Henriksen JazzAmp 110 Henriksen The Henriksen Jazzamp 110 has the classic jazz tone you've been looking for! Small, lightweight, and reliable. Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers henriksen-jazzamp-10-plus-combo 110 4.0 1
4 5
The anticipation while waiting on the 110 to arrive was certainly justified. A beautifully built package that will probably see me out! I'm currently using it with two Ibanez guitars (a GB-10 and an AF-105) plus two Gibson Custom Shop models (an ES-175 and an ES-335), and all of them deliver a very smooth tone with enough output to easily use in any club venue. I bought mine purely for home use, and I'm 90% satisfied with the results. I do tend to find it a little "boomy" with the bass a...
899.00 DjangoBooks.com
Home / Henriksen JazzAmp 110
The JazzAmpTM 110 provides unmatched warmth and clarity for rich jazz tones in the ultimate package of power and portability. At only 23 pounds the 110 can cover nearly any jazz gig from small rooms to large ones, and because of the linear design it sounds just as great at bedroom volumes.
6905 - Henriksen JazzAmp 110
$899.00 | Out Of Stock | Stock Notification
Amp Specs
Size: 14" X 14" X 8", 23 lbs.
Controls: Volume, 5-band graphic equalizer, reverb with on/off switch and wet/dry mix control.
Power: Maximum power on the JazzAmpTM 10-Plus is 160 watts at 4 ohms (this requires an extension cabinet). As shipped with a single 8 ohm speaker it delivers 120 watts.
Speaker: Eminence® Beta-A 10.
Construction: 11-ply Finland Birch, steel chassis, Tolex covering with metal corners.
Warranty: Full 2 year warranty (see details on warranty page).
Line Out: Yes
Extension Speaker Jack: Yes (must be an 8 ohm speaker cabinet)
230v/115v Selector Switch: Yes
Room for improvement
Pros: Well built and smooth tone.
Cons: Reverb!
The anticipation while waiting on the 110 to arrive was certainly justified. A beautifully built package that will probably see me out! I'm currently using it with two Ibanez guitars (a GB-10 and an AF-105) plus two Gibson Custom Shop models (an ES-175 and an ES-335), and all of them deliver a very smooth tone with enough output to easily use in any club venue. I bought mine purely for home use, and I'm 90% satisfied with the results. I do tend to find it a little "boomy" with the bass anywhere around the half-way position, but that could be due to the relatively small size of the playing room. (Although it's the exact opposite with a Fender Blues Junior 111 !). I must say that I hate the reverb with a passion, and revert to a TC Electronics pedal for my reverb needs. It just sounds plain awful! That aside, I'm quite satisfied with my purchase, and strangely enough, the cheapest guitar in my set gains the most from it. Thanks.
Submitted by: Yukihyo on 12/19/2011 04:04:25 PM
Henriksen JazzAmp 310 Gig Bag
Heavy duty padded gig bag for carrying your JazzAmpTM 310 around town. The front pocket is large enough for music books, pedals, cables and more.
$119.00
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.012729 Seconds Memory Usage: 1.239418 Megabytes
