Fishman Rare Earth Blend Soundhole Pickup Fishman Rare Earth Blend Soundhole Pickup Fishman The Fishman Rare Earth Blend Soundhole Pickup blends a humbucking pickup with an electret condenser microphone for capturing both the initial attack and sound chamber resonance for true acoustic tone plus power and projection. Arts & Entertainment > Musical Instrument Accessories > String Instrument Accessories > Guitar Accessories > Acoustic Guitar Pickups fishman-rare-earth-blend PRO-REP-103 275.95 DjangoBooks.com
Home / Amplification / Pickups / Fishman Rare Earth Blend Soundhole Pickup
Great acoustic tones from Fishman!
Fishman's Rare Earth Blend merges the humbucking Rare Earth pickup with a high-quality internally mounted microphone for a "best of both worlds" approach to acoustic guitar amplification. The microphone is a mini hypercardioid electret for high volume and low feedback performance. The system combines the percussive attack and controlled sustain of the magnetic pickup with the resonant, ambient qualities captured by an internal microphone. Neodymium (a rare earth element, hence the name Rare Earth pickup) magnets provide excellent string-to-string balance, while the discrete circuitry keeps the Rare Earth's signal pure and clean.
Fishman Rare Earth Humbucking Pickup at a Glance:
The Pickup
This Fishman Rare Earth pickup is a "stacked coil" style, for musicians who demand quieter reproduction than a single coil pickup can offer. A brilliance knob, located on the side of the pickup, is easily accessible through the soundhole. In the "up" position, this knob provides a subtle, rising treble boost, from 2kHz to 20kHz. This position is especially effective for adding a bit of extra sparkle to finger style playing. In the "down" position, it provides a flat response, which produces a mellower sound, well suited for strumming and flatpicking.
The Preamp
The preamp is housed within the pickup. A low noise circuit design preserves the pickup's performance in any audio environment. The preamp allows you to plug the Rare Earth into a full range instrument amplifier, an unbalanced input of a PA system, a recording console or direct box, without the signal loss or degradation typically found with passive soundhole pickups. You may run cables up to 80' (25m) in length without any audible loss of fidelity.
Fishman Rare Earth Blend Acoustic Pickup Features:
Cutting-edge neodymium (a rare earth element) magnets
High-quality internally mounted microphone with hypercardioid polar pattern
Three-dimensional amplified acoustic guitar tone
Gooseneck is permanently attached
Can be plugged into an instrument amplifier, sound reinforcement system, recording console or direct box
Miniature battery mounts conveniently on the underside of the pickup (batteries included)
Low current design of the preamp allows 150 hours use between battery changes
Fits in soundholes as small as 3-5/8" diameter
Pre-wired output jack can also be endpin mounted
Active electronics for a pure, clean sound
Excellent string-to-string balance
Humbucking performance from the Fishman Rare Earth Blend acoustic pickup!
6600 - Fishman Rare Earth Blend Soundhole Pickup
$476.85 $275.95 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.030127 Seconds Memory Usage: 4.282745 Megabytes
