Fishman Pro EQ Platinum Acoustic Guitar Preamp Fishman Pro EQ Platinum Acoustic Guitar Preamp   Fishman The Fishman Pro EQ Platinum is an acoustic guitar preamp that utilizes a 4-band equalizer modeled after the versatile Prefix Plus. Arts & Entertainment fishman-pro-eq-platinum PRO-PLT-101 135.91 DjangoBooks.com
Home / Fishman Pro EQ Platinum Acoustic Guitar Preamp
A feature-loaded pre-amp/DI.
The Fishman Pro EQ Platinum is an acoustic guitar preamp that utilizes a 4-band equalizer modeled after the versatile Prefix Plus. Each band is assigned to just the right frequencies for acoustic equalization. Also borrowed from the Prefix Plus design are feedback-fighting phase and notch controls. An innovative "smooth" compression circuit has been added to subdue explosive high frequencies when you strum hard or snap the strings. The Fishman Pro EQ Platinum also features a balanced XLR output, allowing it to be powered by phantom power. The ground lift feature is designed to function even when phantom power's applied to the preamp.
6600 - Fishman Pro EQ Platinum Acoustic Guitar Preamp
$384.54 $135.91 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.011475 Seconds Memory Usage: 1.180679 Megabytes
