Fishman Platinum Stage Class-A EQ/DI Fishman Platinum Stage Class-A EQ/DI Fishman The Fishman Platinum Stage preamp/DI also includes a soft-knee compressor, an effects loop, and a sweepable notch filter - everything you need to tweak your sound to perfection. Arts & Entertainment fishman-platinum-stage PRO-PLT-301 109.95 DjangoBooks.com
Home / Fishman Pickups and Preamps / Fishman Platinum Stage Class-A EQ/DI
The Ideal Preamp for the Mobile Acoustic Musician
Whether you play acoustic guitar, upright bass, or any other acoustic instrument, Sweetwater knows you need versatile, great-sounding amplification. And that's exactly what you get with the Fishman Platinum Stage preamp/DI. At the heart of the Platinum Stage lies a crystal-clear Class A instrument preamplifier designed to get the full sound from your instrument's acoustic pickup. Onboard, you'll find a 4-band tone control with sweepable mids, a feedback-fighting phase switch, a pre/post-EQ balanced DI with an auto-ground lift, and a switchable gain boost to help you cut through the mix. And as a bonus, you can run the Fishman Platinum Stage can run entirely off phantom power.
Compressor, FX loop, and more
The Fishman Platinum Stage preamp/DI also includes a soft-knee compressor, an effects loop, and a sweepable notch filter - everything you need to tweak your sound to perfection. Add in the included belt clip, and the Platinum Stage becomes the mobile instrumentalist's ideal busking buddy. And when you're in the studio, you can power it via 48V phantom power, giving you complete control over your sound without batteries!
Fishman Platinum Stage Universal Instrument Preamp/DI Features at a Glance:
  • 17-volt, high-headroom, discrete Class A preamp
  • 4-band tone control with sweep-mid and low frequency filter
  • Guitar/bass EQ modes tailor EQ for your instrument
  • Volume boost switch with level control; phase control
  • Balanced DI with pre/post EQ setting and auto-ground lift
  • Belt-clip included
Tech Specs
Pedal Type EQ/DI
Inputs 1 x 1/4"
Outputs 1 x 1/4", 1 x XLR
Power Supply Included No
Batteries 1 x 9V
Height 1.2"
Width 3.3"
Depth 5.6"
Get the best sound from your acoustic instrument with Fishman's Platinum Stage!
6600 - Fishman Platinum Stage Class-A EQ/DI
$184.54 $109.95 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.013551 Seconds Memory Usage: 1.353798 Megabytes
