Fishman Platinum Pro EQ Fishman Platinum Pro EQ Fishman The Fishman Platinum Pro EQ Preamp/EQ/DI delivers pristine acoustic guitar sound, onstage and in the studio. Arts & Entertainment fishman-platinum-pro-eq PRO-PLT-201 229.95 DjangoBooks.com
Home / Fishman Pickups and Preamps / Fishman Platinum Pro EQ
Killer Acoustic Guitar Preamp/EQ/DI!
The Fishman Platinum Pro EQ Preamp/EQ/DI delivers pristine acoustic guitar sound, onstage and in the studio. The Platinum Pro EQ rocks easy-to-use controls that let you quickly dial in a natural acoustic sound that fills any room, without fear of feedback. A 5-band equalizer with sweepable mids and filtering lets you easily contour the tone of your axe, and a one-knob compressor makes smoothing out your sound a piece of cake. What's more, there's a handy tuner onboard, plus an effects loop and footswitchable boost. You also get a balanced XLR out with a pre/post EQ switch, and a ground-lift switch. At Sweetwater, we dig the Fishman Platinum Pro EQ. We're sure you will, too!
Fishman Platinum Pro EQ Features at a Glance:
  • 17-Volt, high-headroom, discrete Class-A preamp
  • 5-band tone control with sweep-mid & low frequency filter
  • EQ mode tailors EQ for bass or most other instruments
  • Phase control and precision notch filter reduces feedback
  • One-knob adjustable compressor smooths playing dynamics
  • Integrated fully-chromatic digital tuner
  • Volume boost foot switch with level control
  • Balanced XLR D.I. with pre/post EQ setting and ground lift
The Fishman Platinum Pro EQ: everything you need to make your acoustic sound great!
Tech Specs
Pedal Type EQ/DI
Inputs 1 x 1/4"
Outputs 1 x 1/4", 1 x XLR
Power Supply Included No
Batteries 1 x 9V
Height 2.2"
Width 5.6"
Depth 6.2"
6600 - Fishman Platinum Pro EQ
$384.54 $229.95 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.023216 Seconds Memory Usage: 2.273499 Megabytes
