Fishman Loudbox 100 OPEN BOX Fishman Loudbox 100 OPEN BOX Fishman High quality acoustic sound in a lightweight, portable amp. Arts & Entertainment > Musical Instrument Accessories > Musical Instrument Amplifiers fishman-loudbox-100 PRO-LBX-400 5.0 1
5 5
If you want an amp with all of the right features and power to spare for an acoustic singer-songwriter, this is it. I simply plug in and play. Plus, it supports my cardioid microphone with phantom power very nicely. No worries.
439.00 DjangoBooks.com
Home / No Show / Fishman Loudbox 100 OPEN BOX
The Fishman Loudbox 100 Acoustic Guitar Amplifier features 100W, 2 channels, dedicated drivers, and weighs less than 25 lbs. The Fishman Loudbox 100 Acoustic Guitar Amplifier is a superbly portable acoustic instrument amplifier for the active musician.
The secret to the Loudbox 100's sound lies in its 2 power amps and 2-way speaker system. This powerful combination results in higher sound pressure levels and cleaner acoustic tones, watt-for-watt, than comparable acoustic amps.
With all the features a gigging performer demands, this amp meets a variety of needs. Three bands of EQ with feedback-fighting controls give you incredible control over your tone.
You'll find this lightweight and compact amp is as comfortable in your home studio as it is on stage. It easily passes the "one-trip" test, for those times you carry both your instrument and your amp to the car or into the club.
The 2-channel Loudbox 100 brings together a wish list of the essential features you've been looking for. The front panel includes inputs for acoustic instruments, an XLR microphone and a CD player or drum machine. Dual EQ sections include bass, midrange and treble controls for easy, effective tone shaping. Vanquishing troublesome acoustic feedback is simple with independent anti-feedback filters and phase switches for each channel.
Also included are 5 digital effects you can really use: two halls, two plates, and a smooth chorus. A convenient mute switch keeps things quiet when you tune up or take a break. The Loudbox 100 also features a headphone jack for silent jamming or practicing.
On the rear panel, good things come in threes with D.I.s for channels 1 & 2, plus a third summed Mix-D.I. output (watch your soundperson smile). For pedal-heads, each channel has its own effects loop, a tuner out (Ch.1) and a 1/4" jack for a remote mute switch. With the Loudbox 100 on the floor, the speaker's ten-degree tilt-back angle helps to project your sound up to ear level. So what are you waiting for? Grab your guitar and your Loudbox 100 and go out and make some music!
6600 - Fishman Loudbox 100 OPEN BOX
$930.00 $439.00 | Out Of Stock | Stock Notification
Amp Specs
Power: 100W RMS cumulative, bi-amped with active crossover and master volume
Drivers: 8" woofer (90W), 1" neodymium soft dome tweeter (10W)
SPL @ 1 meter: 114dB SPL
Auxiliary stereo input with level control
Digital effects: hall 1 & 2, plate 1 & 2, chorus, with master level
D.I. output: balanced XLR outputs for instrument channel, instrument/mic channel, main mix
Tuner output
Headphone output
Mute for instrument and inst/mic channels
Dimensions: 16" H x 15.5" W x 11.2" D (40.5cm x 34cm x 29cm)
Weight: 23 lbs.
Fishman Loudbox 100 Manual
No worries amp
Submitted by: Rob on 08/12/2011 06:03:23 AM
Dual-button Footswitch for the Loudbox Amplifier with Remote Switching and Effects Muting
$46.08 $24.95 (Save 46%)
Out Of Stock
Fishman Loudbox Artist Cover
$50.00 $24.95 (Save 50%)
Out Of Stock
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.018051 Seconds Memory Usage: 1.955925 Megabytes
