Home / Evans Custom Amplifiers / Evans RES200 Extension Speaker
The RES200 is the preferred speaker cabinet for your RE200 or AH200 because of its’ quick attack and ultra-portability. It has a ten inch neo speaker, but don’t let this enclosure’s small size fool you. Your ears won’t believe your eyes, when you hear the gorgeous full range sound of this diminutive cabinet.
Legendary seven string wizard, Ron Eschete’ requires an extension speaker cabinet that can cleanly handle his low A (55Hz) string without making him “wait for the notes”. That’s why we use a select wood laminate in an open back design to maximize the RES200’s bass response, upper end clarity and ambient dynamics.
Call or click today to get your new RES200, the one his legendship can’t outplay!
Item: 6808
$496.00 | Out of Stock | Stock Notification
Amp Specs
  • 10” Neodymium Speaker
  • Tilt Back Foot
  • 15 ¾ ”H x 15 ½”W x 10 ½”D; 20 lbs.
Evans AH200 Solid State with Gig Bag
Tube like complexity from this reliable solid state amp!
$1,274.00 $1,082.00 (Save 15%)
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.014693 / 1.494431]
