Home / Amplification / Pickups / DPA Microphones / DPA d:vote 4099-P CORE (Piano Mic)
The DPA 4099 Stereo Piano Microphone System incorporates two sensitivity matched 4099 microphones for capturing piano in crucial recording applications. Capture and record piano with pristine detail. The microphones capture subtle nuances and the included magnetic mounts and goosenecks provide secure placement and easy positioning on a piano sound board.
Sensitivity matched 4099 microphones on goosenecks with magnetic mounts
High gain-before-feedback
Flat frequency response
Compact, discreet size
Excellent phase characteristic
Transducer Pre-Polarized Condenser
Polar Pattern Supercardioid
Frequency Response 80Hz - 15kHz with 2dB Soft Boost at 10 - 12kHz
Second-order low-cut filter at 80Hz with DAD4099
Sensitivity 6 mV/Pa; -44,5 dB re. 1 V/Pa
nominal ± 3 dB at 1 kHz
Dynamic Range (Typical) 100dB
Signal-to-Noise Ratio 71dB
A-weighted: Typ. 23 dB(A) re. 20 µPa (max. 26 dB(A))
Maximum Input Sound Level 142dB
Power Requirements For wireless systems: Min. 5V - max. 50V Through DPA Adapter
With DAD4099 or DAD6001-BC 48V phantom power +/-4V
Output Impedance From MicroDot: 30-40 Ohm,
from DAD4099 or DAD6001-BC: 50 Ohm
Output Connectors MicroDot
MicroDot to XLR cable supplied
Pad No
Low Frequency Roll-Off No
Dimensions 0.2 x 1.8" (5.4 x 45mm)
Cable Length - 6' (1.8m)
Weight 1.62 oz (46g)
$1,320.00
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.022406 / 1.990189]
