DPA 4166 Core Slim Flex Headset Microphone - Beige DPA 4166 Core Slim Flex Headset Microphone - Beige DPA Miniature Omnidirectional Condenser Headworn Mic - Biege Electronics > Audio > Audio Components > Microphones dpa-dfine-omini-biege FIOF00 780.00 DjangoBooks.com
Home / Amplification / Pickups / DPA 4166 Core Slim Flex Headset Microphone - Beige
DPA d:fine Omni Headset Mic at a Glance:
Crystal Clear Audio
Fits Everyone
Mic Sensitivity
Crystal Clear AudioThanks to the d:fine Omni headset mic picking up vocals is easy, placement is less critical with omnidirectional mics so even untrained personnel can set it up. The high SPL levels are great not only for speaking, but will easily handle singing too, making the d:fine a very flexible head worn mic for conferences, churches, stages and more.
Fits EveryoneYou will love the design of this one-ear headset. The d:fine Omni headset mic was ergonomically designed to fit any ear and head shape, and can be mounted on either the right or left side of the head.
Mic SensitivityThe sensitivity is 6mV/Pa to match the level of the human voice to the general input sensitivity of most wireless transmitters. The noise floor of the d:fine is 26dB(A) re. 20 mUPa and if powered correctly the microphone will be able to handle sound pressure levels up to 144dB SPL before clipping occurs. A wide range of connection adapters makes it possible to use the d:fine Omni headset mic with most of the professional wireless systems available plus 48 V phantom XLR connection.
DPA d:fine Omni Headset Mic Features:
Crystal Clear audio
Universal fit
Wired or wireless operation
Add a great sounding and discreet mic to your collection with the d:fine Omni headset mic.
Tech Specs
Compatibility Adapter Required for Wireless Connection
Connector MicroDot
Color Biege
Polar Pattern Omni
Microphone Type Condenser
Frequency Response 20Hz-20kHz
Max SPL 144dB SPL
Signal to Noise Ratio 68dB (A weighted)
Self Noise 26dB (A weighted)
Cable Length 4.3 ft.
Weight 0.30 oz.
Manufacturer Part Number FIOF00
DPA d:fine Omni Headset Mic - Omni, Biege
6905 - DPA d:fine Omni Headset Mic - Omni, Biege
$780.00 | Out Of Stock | Stock Notification
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.017684 Seconds Memory Usage: 1.892738 Megabytes
