DPA 4288 CORE Directional Flex Earset Microphone with MicroDot Connector - Medium Length, Brown DPA 4288 CORE Directional Flex Earset Microphone with MicroDot Connector - Medium Length, Brown DPA Miniature Cardioid Condenser Headworn Mic - Brown Electronics > Audio > Audio Components > Microphones dpa-dfine-cardioid-brown FIDC00 880.00 DjangoBooks.com
Home / Amplification / Pickups / DPA 4288 CORE Directional Flex Earset Microphone with MicroDot Connector - Medium Length, Brown
d:fine Directional Headset Mic at a Glance:
Crystal Clear Audio
Fits Everyone
Mic Sensitivity
Crystal Clear AudioThanks to the d:fine Directional headset mic's cardioid pattern it rejects extraneous side and background noise that you want left out of your signal, this also creates a higher gain-to-feedback ratio. The high SPL levels are great not only for speaking, but will easily handle singing too, making the d:fine a very flexible head worn mic for conferences, churches, stages and more.
Fits EveryoneYou will love the design of this one-ear headset. The d:fine Directional headset mic was ergonomically designed to fit any ear and head shape, and can be mounted on either the right or left side of the head.
Mic SensitivityThe sensitivity is 6mV/Pa to match the level of the human voice to the general input sensitivity of most wireless transmitters. The noise floor of the d:fine is 26dB(A) re. 20 mUPa and if powered correctly the microphone will be able to handle sound pressure levels up to 144dB SPL before clipping occurs. A wide range of connection adapters makes it possible to use the d:fine Directional headset mic with most of the professional wireless systems available plus 48 V phantom XLR connection.
d:fine Directional Headset Mic Features:
Rejects side and background noise
Crystal Clear audio
Universal fit
Wired or wireless operation
Add a great sounding and discreet mic to your collection with the d:fine Directional headset mic.
Tech Specs
Compatibility Adapter Required for Wireless Connection
Connector MicroDot
Color Brown
Polar Pattern Cardioid
Microphone Type Condenser
Frequency Response 20Hz-20kHz
Max SPL 144dB SPL
Signal to Noise Ratio 66dB (A weighted)
Self Noise 28dB (A weighted)
Cable Length 4.3 ft.
Weight 0.30 oz.
Manufacturer Part Number FIDC00
$880.00
Software: Kryptronic eCommerce, Copyright 1999-2025 Kryptronic, Inc. Exec Time: 0.033217 Seconds Memory Usage: 4.925308 Megabytes
