Home / Amplification / Pickups / DPA 4091
DPA 4091
Sleek and sturdy, the DPA 4091 is an excellent omnidirectional condenser microphone that will meet nearly any studio or live sound challenge. With 144dB SPL handling, the 4091 sounds great on percussion instruments and guitar amps, yet will deliver its natural and open sound on wind and string instruments as well. The DPA 4091 also features the same incredibly linear frequency response in the 20Hz-20kHz range as DPA's 4090 - a necessity for properly tuning, aligning, and testing sound systems. Epitomizing versatility, the DPA4091 is an excellent member of the DPA line.
DPA 4091 Condenser Microphone at a Glance:
Versatile miking applications
Linear frequency response
The DPA 4091 has 144dB SPL handling, meaning it can be used on a variety of instruments. Mic a drum kit one night, a cello the next, or use one on each guitarist's amp - the DPA 4091 sounds natural and open on nearly any instrument you put in front of it.
With its linear frequency response in the 20Hz-20kHz range, the DPA 4091 can be used to tune and test any sound system before the crowd starts arriving.
DPA 4091 Condenser Microphone Features:
Pre-polarized condenser microphone
Omnidirectional
48V phantom power
20Hz-20kHz frequency range
97dB dynamic range
40 ohm output impedance
144dB max SPL
3-pin XLR connector
The DPA 4091 omnidirectional condenser microphone sounds great both in the studio and on the stage!
Tech Specs
Microphone Type Condenser
Polar Pattern Omni
Diaphragm Size .21" (5.4mm)
Frequency Response 20Hz-20kHz
Max SPL 144dB SPL
Output Impedance 40 ohms
Signal to Noise Ratio 68dB (A weighted)
Self Noise 26dB (A weighted)
Low Cut Filter No Filter
Pads No Pad
Connector XLR
Weight 1.34 lbs.
Manufacturer Part Number 4091
$675.00
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.015892 / 1.440765]
