Home / Amplification / Pickups / DPA 4006A
DPA 4006A
Since its release in 1982 the Type 4006 microphone has become a worldwide studio standard. It's one of the most popular Standard Microphones in DPA's line. This omnidirectional recording mic features an extremely linear frequency response from 20Hz to 20kHz, high sensitivity and a low noise-floor. The 4006 is phantom powered (P48), which together with the extended range of acoustic pressure equalizers and different protection grids turns the 4006 into an extremely cost effective solution. All in all, the Type 4006 can be changed into 7 different microphone versions acoustically. The 4006 has gained its reputation through its total transparency in both the near-field and in the diffuse field. It's a must for any professional studio.
Tech Specs
Microphone Type Condenser
Polar Pattern Omni
Frequency Response 20Hz-20kHz
Max SPL 139dB SPL (1% THD)
Output Impedance 200 ohms
Signal to Noise Ratio 79dB (A weighted)
Self Noise 15dB (A weighted)
Low Cut Filter No Filter
Pads No Pad
Connector XLR
Weight .4 lb.
Manufacturer Part Number 4006-A
$2,500.00
Kryptronic eCommerce, Copyright 1999-2026 Kryptronic, Inc. - https://kryptronic.com/ [0.021166 / 2.543617]
